Thread: Need assistance with 2500A BIN oading |
New member Username: Dishy
Post Number: 5 Registered: May-06
| Posted on Saturday, June 10, 2006 - 11:07 pm: |
Guys I've been trying to load the new bin for my Pansat 2500a but keep getting bin failure error. I unzipped the bin, tried to use several different loaders for 2500a but same result. I know it's not the cable becuase I used the same cable to load bins for the 2700a with no problem. If anyone has any ideas on a resolution please help me out. |
Bronze Member Username: Rsmc73
Post Number: 57 Registered: Mar-06
| Posted on Saturday, June 10, 2006 - 11:14 pm: |
C&P You must use a Windows XP computer for programming receiver. Connect your receiver to your computer with the serial cable, and power up the receiver. Load up the "2300_2500_1500 Downloader" software. Select the correct “Serial Port” for your system (usually com 1) “Baud” Should be “115200”. For “STB Model” enter "key:global" exactly, without the quotes. Under Bin File select the “277T” file. Click "Download" and wait for your RECEIVER to be updated. Note that you must wait for the message "Download Complete", at which point your RECEIVER will reboot. DO NOT STOP UPDATING OR DISCONNECT YOUR CABLE WHEN IT REACHES "100%" - WAIT FOR THE "DOWNLOAD COMPLETE" MESSAGE!
Post Number: 6 Registered: May-06
| Posted on Saturday, June 10, 2006 - 11:36 pm: |
rsmc73 thanks for the input, perhaps the STB Model is where I go wrong. I did everything as in your instructions , however I was not too clear on what to enter for STB Model I tried "2500", then "2500a", then "pansat 2500a" to no avail. could you elaborate on the on the key:global? is that literally what needed to be enter? thank you |
Post Number: 65 Registered: Mar-06
| Posted on Saturday, June 10, 2006 - 11:58 pm: |
yes enter key:global not panst2500a |
Bronze Member Username: Nick32058
Asdfvafdsv,
QC
Sdv
Post Number: 56 Registered: Mar-06
| Posted on Saturday, June 10, 2006 - 11:59 pm: |
What loader are you using? |
Bronze Member Username: Tadon
Dover,
NJ
Usa
Post Number: 15 Registered: May-06
| Posted on Sunday, June 11, 2006 - 12:02 am: |
What is message say ? STB : you just type "pansat 2500a" (should have a sapce between Pansat & 2500a . ggod luck |
Post Number: 66 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 12:03 am: |
2300_2500_1500 Downloader |
Asdfvafdsv,
QC
Sdv
| Posted on Sunday, June 11, 2006 - 12:04 am: |
Wrong you need BL loader |
New member Username: Abdou91
514
Post Number: 6 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 12:06 am: |
you have to use a RS232 cable a staight not null modem your usig the last one is for pansat 2700 there is cable's list: iza Ultra 400/500- Null Astrovox 2600-Straight DB9 Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)-Null *Coolsa 4000 Plus-Null *Coolsa 4000 Pro-Straight DB9 *Cooltec-Null Coship (All)-Null Digiwave 6800/7000-Null Digiwave Diamond-Straight DB9 Dreambox (All)-Null Fortec lifetime-Straight DB9 Fortec Lifetime Ultra-Straight DB9 Lava 2600-Null Max 2500-Null ****sat (All)-Straight DB9 Microroyal (All)-Null Pansat 2300a/2500a and all clones-Straight DB9 Pansat 2700-Null Pansat 3500-Null Pansat 5000HC-Null(Also can program through USB) Pantec/Multistar Max (All)-Null Pantec/Multistar MS (All except MS1000)-Straight DB9 Pantec MX/Ultra-Straight DB9 Rex1-Null Silver bullet/ST 1000/2000-Null Skyview 500-Straight DB9 Spacestar DVB500-null Stealth 2000a-Null Ultrastar 5000-Null Viewsat VS2000-Null |
Post Number: 69 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 12:07 am: |
no i used 2300_2500_1500 Downloader yeasterday for pansat clone. you can use either one i guess |
Asdfvafdsv,
QC
Sdv
Post Number: 58 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 12:09 am: |
2300_2500_1500 Downloader does not work with my Pansat2500a clone if you need BL loader post your e mail and I will send it toyou.
Bronze Member Username: Nickb
New York,
New York
Post Number: 21 Registered: May-06
| Posted on Sunday, June 11, 2006 - 12:15 am: |
Hi there... I have a question about the loader. I loaded on 277t on a FLU using BL\'s 1.3 loader. I thought at the time that was the newest one :S My receiver has been work for about 5 hours now but I just wanted to know if by using that loader 1.3 instead of 1.4 there is any risk to the receiver. Thanksss soo much.. |
Post Number: 71 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 12:16 am: |
dont get me wrong i dont pretend to know every thing. i just try to help with what i have had experiance with. i have used the blacklist loader also i just preferred the 2300_2500_1500 loader and it works for me. |
Asdfvafdsv,
QC
Sdv
Post Number: 60 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 12:17 am: |
cool |
New member Username: Hellas
Post Number: 1 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 12:21 am: |
costapoulos@hotmail.com |
Asdfvafdsv,
QC
Sdv
Post Number: 62 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 12:24 am: |
you got it |
Post Number: 2 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 12:25 am: |
i need bl loader for pansat 2500 clone e-mail costapoulos@hotmail.com
New member Username: Kanthan
| Posted on Sunday, June 11, 2006 - 01:25 am: |
i need a bl loader for pansat 2500a clone, please send it to my email at kanthan_11@yahoo.com |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 828 Registered: May-06
| Posted on Sunday, June 11, 2006 - 01:28 am: |
check the gtloader and bin in dss**tester.com |
New member Username: Todrod
Louisa,
Ky
Usa
| Posted on Sunday, June 11, 2006 - 01:56 am: |
Having trouble loading new 277T file. I've downloaded the 2300_2500_1500 downloader. Set it up as com1,baud 115200, STB as key:gloabal, and bin file as 277T. keeps saying unknown file found. I've went to courious-contraptions and found the link for chancysand's new 277T file and downloaded it and still no worky. I'm new @ this and I know I'm not doing something right.Any help would be greatly appreciated. |
New member Username: Shl
Post Number: 4 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 02:11 am: |
What about Koolsat 5k? I need to use RS232 Straight or RS323 Null Modem? Can it be use USB-2-Serial? |
Louisa,
Ky
Usa
| Posted on Sunday, June 11, 2006 - 02:14 am: |
Forgot to say I have a pansat 2500A and using a RS-232 straight cable. |
514
Post Number: 7 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 08:37 am: |
did y unzip the bin file? is it look like? x-85bl_060610_277t_au_api__211 may be yr file is notthe same or download from othes site |
Bronze Member Username: Hawks134
Post Number: 26 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 08:38 am: |
I need the loader also hawks134@hotmail.com |
Post Number: 5 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 09:54 am: |
i loaded the bin X-85BL_060609_277_au_api_ into my pansat 2500a clone and it fried the power after 2 minutes. please help |
Puerto Rico
Post Number: 845 Registered: May-06
| Posted on Sunday, June 11, 2006 - 09:59 am: |
kanthan do you need turn off the back button. |
Gold Member Username: Lklives
Post Number: 3198 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 10:01 am: |
U do NOT need windows XP.....ANY window OS will usually work!....people should NOT give out BOGUS info! kan..U needed to use Clone SAFE bin (277T)...not 277...U cannot use genuine bins ...now U must Jtag your receiver....good luck! |
Post Number: 30 Registered: Jan-06
I can not do a factory flash...please help |
New member Username: Alibaba_can
Post Number: 9 Registered: Nov-05
| Posted on Sunday, June 11, 2006 - 10:03 am: |
What exactly do I right in the STB box for Multi pantec Ultra |
Post Number: 3199 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 10:05 am: |
we cannot help...ONLY U can do it!...its just U, the cable, the bin, receiver and computer....its very simple..its all about timing and hitting download after the first light! and if "flash failed" message = wrong/defective cable or SERIAL port (NOT USB port) |
Puerto Rico
Post Number: 847 Registered: May-06
| Posted on Sunday, June 11, 2006 - 10:07 am: |
Pansat Files » X85BL CLONE SAFE for 2500's by Chancysand (June-10-2006) Finally here it is, the clone safe bin for all 2500 clones!!!!!!! By the one and only Chancysand! Date: 10/06/2006 - View Full Info - Downloads: 1114 - Download X85BL CLONE SAFE for 2500's by Chancysand (June-10-2006) (335.98KB) |
Post Number: 3208 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 10:49 am: |
key: global |
Bronze Member Username: Orbitekcomm
Post Number: 19 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 11:54 am: |
Is it possible for my to use an RS-232 9 pin to 25 pin cable in my com3 port to execute this download. My laptop only has a 25 pin port, not 9 pin port. And how come when I hit download, after 1 second, the entire program shutsdown, and it keeps doing that? |
New member Username: Bthitman
Post Number: 10 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 01:22 pm: |
rich,have you worked out your problem yet ? If not post your e-mail I'll send you what I have. |
Post Number: 23 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 03:05 pm: |
No I have not yet worked out the problem. I have a pansat 2500a reciever. Can you also tell me what loader I need to use. My email address is orbitekcomm@yahoo.com. Thank You! |
