Home > Message Board > Home Video > DVD Recorders > Archive through August 24, 2006 > Maximum Limits On Blank DVD's
Author Thread: Maximum Limits On Blank DVD's
Username: G1984
Oregon
I know that the maximum limits for the different recording modes are a little longer than it says on the package (I.e. SP mode can record a few minutes longer than the 2 hours the package says). Could someone post a listing of the different speeds and the actual recording times for each?
Thanks in Advance,
Garr.
Username: Samijubal
Post Number: 2708
It depends on the recorder. The shortest I've seen is slightly over 2 hours, the longest just under 2 hours 10 minutes in SP.
Username: G1984
Oregon
I own an aspire DVD recorder. It's cheap, I had a lot of trouble with it when I first got it (Christmas '04), but then I figured out how to use it, and got the software update from Aspire, and it's been smooth sailing ever since!
Username: Samijubal
Post Number: 2709
Never used one of those. You'll just have to figure it out since it varies with each recorder.
Username: Mhykal
Pensacola, Florida
problems with cyberhome dvr,replace the burner.i used the one in my computer and it,s been working fine for 8 months.
Home > Message Board > Home Video > DVD Recorders > Archive through August 24, 2006 > Maximum Limits On Blank DVD's [ « Previous ] [ Next » ]
