Home > Message Board > Home Video > Satellite TV > Archive through June 12, 2006 > ALL INTERNATIONAL WORKING!!!!
Author Thread: ALL INTERNATIONAL WORKING!!!!
Username: Emperorrotm
Post Number: 11
ALL INTERNATIONAL CHANNELS ON 61.5 ARE WORKING WHEN YOU GET THE NEW BIN!!!!
Username: Esteban26
Santo Domingo, Distrito Nac...
Republica Do...
Pleasse can somebody tell me which is the new bin.
Thanks
Username: Vasia22
which bin do i use for FORSAT 2500 Ultra?
Username: Minmike
Post Number: 9
which bin i can use for fortec lifetime classic na or a colsat
Username: Adave
what about c**lsat 5k
Username: Rkanak
Post Number: 30
the bins for most of the receivers are located at dsstester dot com, al7bar dot tk future-fta dot info
Username: Dafee99
Post Number: 106
I've seen a bin for the fortec lifetime classic na... , and the rest are also available at the link "jose" cut and paste on the new keys thread... just press go on the bottom and the page updates... (no registration was needed when i got in... like always test at own risk
Username: R1010
Post Number: 35
rajesh >>>>>> plz help me how i can get the bin plz guide me i went on that site the one you gust posted but i don't understand what to do there plz don't mined ust guide me
Username: Chababe
what about REX-I there is any hope that it will work?
please answer me
Username: Pecheche
Anybody know if the fix for Microyal 1200 is out yet?
Username: Brownraider
are the internationals working on 148???
Username: Princess1_43
Hey
iam really lost .... iam using fortec ultra ... and i know we dont need to change the keys or anything.. but i have read that we need to get a bin file or change the position to something...
can some one please explain this to me... i dont know that much about it .. All i know our dish is set up on Echo3 and Echo 8 ?
*Saniya*
Username: Nadiad
Helloooo
How do I get new BIN to get ALL INTERNATIONAL CHANNELS??
please advise.
Username: Naren3001
hi guys!
I have been reading all this since last one week but can someone tell me about cooltech 4000 pro?
Is there any file available for this?
Username: Sonya
Hi Guys!
Do you have a fix for digiwav 7000. I was reading through the website and was not able to find any fix for digiwav 7000. can you help this helpless girl please.
thanks
Username: Rekman
Longueuil, Quebec
CANADA
Hellooooooooo can any1 explaijn to me Whats a BIN I cant understand what u r talking about BIN. plz explain.
Username: Evadelparaiso
Puerto Rico
Post Number: 744
For ALL Pansats....
Things you will need!
1.A computer with a com port!
2.The right cable to connect to your computer to your receiver!
3.The most recently LOADER
4.New pansat bin!..
5.LNB setup and the right switch!
6.Sat Signal at 70 percent or higher!
1.Power down receiver and computer!
2.Connect receiver to computer and power both of them up!
3.Start up gtrom newest version and select the new bin file you wish to upload then click download wait until it is finished it will go to a 100 percent but it is not finish until it displays burn complete or finished!
4.Turn off power to receiver and computer and remove the cable from the receiver!
5.Install cable from the lnb and the cable from the tv and the plug it up and power up the receiver!
6.Using your remote hit menu and the parent control then ok in second pin enter 0000 and then ok!
7.Then set default key..EMU-ON then ok!
8.Go to Nagavision2 then ok and check 00 and 01 keys. Put in new keys if need then hit ok to save!
9.Now installation then ok antenna setup then ok make sure you have 110 and 119 and check to make sure the switch is set right for both on the diseqc setting! If 110 is on 1 and 119 is on 2, set diseqc the same way!
10.Now go to blind scan and hit ok!
11.When finished exit menu and watch tv!
Puerto Rico
Post Number: 745
Bin:Binary file, a computer file that comprises a sequence of encoded numerical values rather than human-readable text, including an
Executable file, a computer file containing machine code that can be executed by a specific operating system
Username: Jmontana1
Post Number: 53
ok people as i said couple days ago blacklist is back last night witha new fix for pansat!
he arrived at 6pm from germany with no brake he realases new fix around 11.32pm
enjoy
Username: Jawaharyousuf
Post Number: 8
Apparently, its hanging up fortec ultra. So, i don't wanna try till they have a good file out for ultras. I can wait..
Username: Sonya
Post Number: 7
My lovely friends!
Do you have a fix for digiwav 7000. Please reply
thanks
Username: Saltyswift
How come some international channels are not working with the new bin on Pansat 2700?
Polsat and ITVN are down.
Anyone know why?
On my autoroll menu, I have keycode, Dishnet, BEV and GlobeCast all set to ON.
Should I change something?
I already pressed Set Default Key and I'm getting all channels EXCEPT for Polsat and ITVN.
Anyone know why?
Username: Rith
Hey Eva I Noticed you are very smart, can you please be so kind to post step by step instructions to download new bin in a Pansat3500S by using SD CARD..Do I need to make a back up from Pansat first? Do I need to dowload channel list again?
Thanks in advance Eva
Username: Rith
can someone please be so kind to post step by step instructions to download new bin in a Pansat3500S by using SD CARD..Do I need to make a back up from Pansat first? Do I need to dowload channel list again?
Thanks in advance
Username: Bthitman
Can anyone tell me what program I need to load the new BIN into my Pansat 2500 Please ?
Username: Vndpatel
Post Number: 49
http://www.dss*central.net/files/index.php?act=view&id=1122
thats the new bin
Username: Vndpatel
Post Number: 51
tell me if it works
Username: Boyce
Post Number: 250
remote manual-> SD memory -> channel folder -> backup channel. Remove the SD from recevier to the PC, copy the bin file (extracted) to the sd card code folder, put the sd card back to the 3500,remote manual -> SD memory -> code folder -> bin file 277 -> restore.
After reboot,option 1 same as above, but goto channel folder, look for the channel file you backup before, restore.
option 2 delete all channel, and blind scan satellite which you installed before.
BTW I alway have B70 problem after use SD update, therefor I always use cable update for now.
Username: Tbedoya
Bayonne, Nj
Us
Post Number: 10
any one know the n2 keys
Username: Bthitman
Post Number: 7
Hey thanks bob john. I was told that I need another program to load the bin from my computer to the receiver. Is this true ?
Username: Sting77
hi can somebody give me the safe bin for pantec or pansat2500a plz i am new really need help
thanx
Username: Vndpatel
Post Number: 52
no ,does your reciever work?
Username: Keanos
Post Number: 22
Username: Vndpatel
Post Number: 53
go there tell me if it works. its for pansat 2700a
Username: Indopak
i have a fortec lifetime ultra.. and i downloaded the new bin 277, and it says scramble or bad channel.. what should i do..
Username: Indopak
i have a fortec lifetime ultra reciever, and i just donwload the new bin 277, but it says scramble or bad channel.. what should i do??
Username: Vndpatel
Post Number: 54
only viewsat and pansat are working
Username: Viet004
try this everyone http://www.dss*central.net/files/index.php?act=view&id=1122.com
wait for the download sign at the bottom
Username: Nabil
Post Number: 12
please help!
i tried to download the bin file but it didn't work....i can't download it...what could be the problem???
Username: Keanos
Post Number: 25
can somebody tell me which is the new bin. numero
Username: H_brutus75
kamal:
the problem is that there is too many people using this link at the same time..
Username: Cosmic_ray
Toronto, Ontario
CANADA
Post Number: 34
Kamal !
Do need file for PANSAT 2700A ?
If so send me email madonafergusan@hotmail.com
I shall send you from my HD.
Username: Nabil
Post Number: 13
could someone help me please!!
i download the new bin on my pansat 2500a but when i go to the menu, parental control, i dont have the second pin number......so how could i enter the keys????
Username: Backdoor
i have a receiver which is dish-311 and want to know if i can still use it and if so how could i programe it anyone help me
regards
Username: Zmkn2000
Mississauga, On
EVA or someone who can help me: i have ariza 700. i have no idea where to go and what to do. can u tell me in english and no short term terminology what to do? i would be ever so grateful! thanks.
Username: Naren3001
Post Number: 9
can someone help me for my cooltec 4000?
Username: R1010
Post Number: 38
HI CAN ANY ONE TELL ME WHO I CAN FINED THE (STB) NUMBER OR WHAT I HAVE TO WRITE WHERE IT SAYS WRITE YOUR STB NAME CAN SOME ONE TELL ME I HAVE PANST EAGLE STAR RECIVER FREE TO AIR HELP PLZ
Username: Johnny0786
New bin is X-05BL_060609_352eubx_api_au_1
key0
98 f7 44 AC 5E 07 D9 ED
8A FF 3B 7E 65 71 F9 4E
Key1
71 9C 60 71 04 C1 39 AE
88 FF F0 5E D2 4C F3 FC
Username: Ssparkle0316
Post Number: 15
for wht reciever
Username: Gemtomas
Hi
Very good forum and best help.
Can you help? I can't find the russian channels those was on eco9. .I have co**lsat 4000 and newest bin.I did search in this forum but i did'nt find about russian channels or maybe i miss somthing or i did wrong search.
Help me plz and Thanks alot.
You cand send me answer on my email gemtomas@yahoo.com
Thanks
Home > Message Board > Home Video > Satellite TV > Archive through June 12, 2006 > ALL INTERNATIONAL WORKING!!!! [ « Previous ] [ Next » ]
