Thread: Cable Box, or not |
New member Username: Bob_j
Post Number: 1 Registered: Jun-06
| Posted on Wednesday, June 07, 2006 - 01:17 pm: |
I'll be buying a Sony 26" LCD for mounting above the mantle in the bedroom. There isn't a suitable place for the Comcast digital cable box. I understand the loss of features with a cablecard and would like those features on the tv, so I think I need the box. The electrician is working in the bedroom and I need to give him some direction. Question: Is there a way to hide the cable box out of view (in a closet) and still get the signal from the remote to the box? Any other suggestions? Thanks much. |
Bronze Member Username: Justfig
Maynardville,
TN
Post Number: 25 Registered: Nov-05
| Posted on Thursday, June 08, 2006 - 08:51 pm: |
Bob, you can get an remote IR emitter and a sensor. That way you can put the cablebox in a closet or anywhere you want to out of site. Go to this website (http://www.hometech.com/) call them up and tell them what you are wanting to do. They have what you need. JF |
Post Number: 2 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 02:15 pm: |
Thank you very much. I'll give them a call. |
New member Username: Srewick
Post Number: 1 Registered: Jul-06
| Posted on Monday, July 17, 2006 - 12:56 am: |
I have comcast cable and am trying to connect DVI to HDMI. Seems like that part went relatively easy. The part that is killing me is that I cannot seem to connect my audio (tried on both of my plasmas -- have a new Phillips and a new ProView). Is there a secret here? I thought it was as easy as red/white to red/white. What am i missing!? Thanks in advance for any help that is offered! |
