Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > Pansat 3500s will not turn on
Author Thread: Pansat 3500s will not turn on
Username: Sledneckmpower
Hi I'm what you call a newbie. Anyways I got my new pansat in the mail there last week hooked it all up read almost every post about how to set it and what to do. So on Friday when everything went for S#@# I was entering keys and doing this and that. Pretty much following instructions off here. Now I have a problem my pansat turns on I get the little green light but nothing else. Is there something a did? How can I fix it. Please help. Thank you! Scott
Its probably something stupid and easy to fix!
Username: Ven101
Same here, I applied the new bin that got released end of May and my receiver was toast.
I just see the green light no output and response to anything, except power on/off.
I tried several times to reload the bin wiht my laptop using the cable, but no luck.
I am suspecting there is no fix, but I respect and believe in the experts of this board. Any help appreciated.
Regards,
Ven
Username: The_wank_artist
Post Number: 714
Try reloading the factory bin, then load an older bin and use that for now.
There was also what was called a 'jtagless' program at dsscentral*net. Now, it says it's for 2500 and 2700's but it's also there, not sure if you would want to try it or not.
The only other option would be to jtag it.
Both can be found here.
http://www.dsscommunity*com/forums/viewforum.php?f=130&sid=78a1bfb36baf867a9ff06d00347e4c96
Username: Boyce
Post Number: 209
I try to look for the post for you, it call B47 fix/or some like that! it is easy fix, please wait a sec, all DSS site is busy.
Username: Wakenbake
Post Number: 150
turn 3500 off from switch in back
hook to computer
have downloader ready w/bin
turn on w/switch, as soon as you see the green hit download and wait till says complete.
(its all in the timing)
Username: Dafee99
Post Number: 85
VEN keep trying... Turn the receiver off from the back and as soon as u see life signal click download.. dont give up
Username: Boyce
Post Number: 210
I guess I don't need look anymore., the post is here.
"turn 3500 off from switch in back
hook to computer
(its all in the timing) "
Wakenbake, good job.
Username: Ven101
Thanks for the quick feedback.
I tried several times to load the bins with no luck. I am using GTRom Loader version 3.4 and version 3.42. Is there a specific version that you recommend?
One think that I observed, with ver 3.4 it does not display any error or will it timeout. But with version 3.42 after about 90 seconds or so the loader will give me a error telling me that it failed "Do you want to retry or igonre?" with buttons.
I am not ready to give up yet, thanks for the support
Regards,
Ven
Username: Wakenbake
Post Number: 153
i use bl loader
future-fta.com
Thanks for the fast feed back everyone! I'm still having no luck but I will keep trying!
Username: Evadelparaiso
Puerto Rico
Post Number: 653
Sledneck check your email for complete instructions. Lucky
Thanks I have a null modem cable is that right?
Puerto Rico
Post Number: 659
. Make sure you use the proper serial cable for your receiver:
Most Fortec and Pansat use a straight through cable with DB9 females on both ends.
The Blackbird, Pansat 2700/3500 and some other receivers use null (crossover) cable, which crosses over pins 2 and 3.
I'm gonna crash and burn before I ever get going. I got all of about 2 hours of tv in since I got this thing. So much to learn. But thanks for the help I will go and pick up the cable tomorrow and try that.
I just took a look at the download instructions and it says to use a null modem cable so I think I got the right one its just getting it to work i downloaded the loader from pansat but is there a diffrant one i could try?
Could my pansat be a clone ? Would the be the reason for all my trouble?
Pansat 3500s
Post Number: 748
Don’t know what yours looks like.
But if it has the sd card slot and looks authentic then chances are no, it's not a clone.
One of the newer bins did create some trouble for some 3500's.
Go to one of the older bins and try that, the 145 I think worked well Sled. You'd have to manually enter the keys but that shouldn't be a problem, it's been posted a hundred times around here how to do it.
Post Number: 7
yeah i had it working and then I updated the bin and thats when it went for sh*% thanks.
Username: Googi
Ontario
Post Number: 29
http://www.extrememicro.c*m/
Username: Googi
Ontario
Post Number: 30
I have this Problem too! What bin loading program should I use, I am currently trying to use GTRom Loader V3.36
Post Number: 788
That GTRom loader should work fine Googi.
Username: Googi
Ontario
Post Number: 31
Is the whole Timing thing going to work? or is there another way to do this, cuz I can't get the timing thing
Post Number: 789
like so many other things in life Googi, it's all about the timing.
Username: Googi
Ontario
Post Number: 33
damn it....i'll keep trying it this way, i'm pretty good with video games such as street fighter so this should be easy, I hope anyway
Post Number: 791
Well that's good Googi, maybe if you try enough times you'll get high-score!!! LOL
Username: Googi
Ontario
Post Number: 34
DAMN! ..........Does anyone wanna buy a Pansat 3500sd? used for about 4 days, Perfect condition, just won't turn on...*sigh*
Username: Parranda
Post Number: 13
googi, how much? :+)
stick in there bud you'll get it to work
Username: Intlms
I have similar problem with my Fortec LU. I just uploaded X-85BL_060609_277_au_api_.bin file bc someone said that it works on their clone unit so i uploaded. After 100% unit turned off then turned back on but it's stuck with receiver's screen saying 'on' and it doesn't do anything or accepts anything. Tried to upload old bin that i had but unit just turns off and my laptop is saying couldn't upload. Any ideas?
Username: British
Post Number: 49
not sure but probably all the above are trying to upload w/usb port?
serial port w/no adapter for usb needed.
Username: British
Post Number: 50
but probably needs jtag, before upload. after jtag, load original bin and then new bin
Username: Googi
Ontario
Post Number: 35
jtag eh? what's that?
Username: Poscor
Post Number: 30
does 3500 have any display at all
Username: Googi
Ontario
Post Number: 36
no, When I switch it on from the back, the green LED (on the front) turns on and nothing else, when I conncet it to the TV (through RCA connections) It doesn't display ANYTHING
Username: Srg200159
where can i fine loder v3.36 at
Username: Googi
Ontario
Post Number: 37
www.extrememicro*com
Username: Googi
Ontario
Post Number: 38
what is Jtagging? and how do I do it?
Username: Googi
Ontario
Post Number: 39
If this Jtagging will work can someone tell me what it is and how to do it or link me, i gotta get the thing working for the World Cup!
Username: Lklives
Post Number: 3167
its a long soldering process and cable making, that U must read about at ANY other DSS site but here..or pay an electronic store $60 to do it!
www.dsstester.c*om ...remove the * in link and then register FREE at site...then do search of Jtag in your receiver type area..
Username: Googi
Ontario
Post Number: 40
Username: Googi
Ontario
Post Number: 41
ohhhh I see
I'm not gonna do it tho lol
Puerto Rico
Post Number: 786
Googi please check in your receiver back for correct instalallion. Your cable maybe its in wrong place.
Username: Devenw
MISIS
Post Number: 23
HELP ME FOR LIFE TIME
Username: Googi
Ontario
Post Number: 42
the RS232 cable I am using always worked before, and I got it with the satellite, I really don't think I am putting it in the wrong port I may be new to this satellit stuff but I would say I am very good with technology.
Puerto Rico
Post Number: 803
Googi ok. :-) Im happy if you are very good with tecnology.
Username: Googi
Ontario
Post Number: 44
thanks...but my skills obviously can't solve this lol, any tips you can give me?
Puerto Rico
Post Number: 809
Googi:
Here are a few tips if you are having difficulty flashing: loading a bin..
I would advise everyone to read a set up guide before flashing. But, since people have been having some problems, I have revised this to provide more detailed information. But this is not intended to be a substitute.
1. Make sure you use the proper serial cable for your receiver:
2, With the power turned off, connect it to your computer and receiver using the serial connector. Use serial port #1 if you can.
3. If you do not have a working SERIAL port, you must install one or use a computer that has one. Usb ports do NOT usually work, except on rare ocassions with an adapter.
4. Use the appropriate loader.
5. Select the file. Make sure that it is the correct flash for your receiver.
6. Select the COM port your receiver is connected to. If you do not know, what it is try #1 first.
7. Enter the correct model name and number. Most Blackist updaters do Not require this.
8. Check off the correct function box. Your choices are boot, flash or channel list. To FLASH your receiver you would use FLASH. Most flashes do not require a separate boot; so do not load both separately.
9. Turn on the receiver power from the BACK switch.
10. As soon as you see the lights flash,very first light -- IMMEDIATELY press download. Timing is critical and many vary.
11. Wait until it COMPLETES and reboots.
_________________
Pansat setup guide..
http://dsscommunity.c*om/forums/viewtopic.php?t=5714
Dishnet keys..
http://dsscommunity.c*om/forums/viewtopic.php?t=3151&start=240
Keymaster 2.0..
http://dsscommunity.c*om/forums/viewtopic.php?t=6560
Puerto Rico
Post Number: 810
Pansat 3500 REprograming
How to Load and Save Files to the Pansat 3500S
3500 - THE SD/MMC WAY:
Insert virgin SD/MMC card into receiver.
Press [menu]
Select [SD Memory]
Note: Receiver will automatically create 3 directories on the card:
CH Data Backup
Code Backup
MP3
(For Virgin cards only -Take the card out at this point and load your unzipped bin or channel list file to the card in the appropriate directory. Now put the card back in and re-access via menu as stated above.)
Select bin file in appropriate directory, main directory, [ch data backup] or [code backup]
Press [OK]
Select [data restore]
Press [OK] to load, receiver will automatically load, confirm, then reboot.
TO SAVE DATA
Insert SD/MMC card into receiver.
Press [menu]
Select [SD Memory]
Select an appropriate directory, main directory, [ch data backup] or [code backup] by using [up or down arrows] and [OK]
Press RED button in left bottom corner of remote.
Name your file on the alphanumeric screen file by scrolling via [arrows] to next character and then pressing [OK] for each character or [del] to correct a character. To save selected name, press [OK] on the alphanumeric screen.
Bin File will then write automatically to the correct directory.
Size of files:
CH = 352 kb
Code = 768 kb
Use GREEN button (beside the RED button) to delete selected and unwanted
files.
http://forum.ecoustics.com/bbs/messages/2/224237.html
Puerto Rico
Post Number: 812
Download Procedure for Pansat 3500S
1. Connect RS232 Null Modem(#2,3 crossed) cable between the receiver and PC.
2. Turn the receiver power ON.
3. Open the GTRom Loader V3.36(Pansat 3500S).
4. Click BIN FILE and select the Bin File to be downloaded.
5. Select FILE TYPE and click Download.
6. Do not interrupt the receiver power while downloading.
7. Press OK after Download Complete!! Appear on the PC screen.
Username: Googi
Ontario
Post Number: 45
alrighty, I JUST purchaced a Jtag thingy off eBay, so when I get it, I hope I can get past this "not working" stupidness!
thanks Eva Diaz for your help....I might need it again soon lol
Username: Laluprasad
352 bin clone my vortax 3500 three time anybody
post for clone safe bin.
Username: Googi
Ontario
Post Number: 46
could the fact that my operating system is Windows Vista make this timing process not work?
Puerto Rico
Post Number: 855
which process jtag? bin?
Username: Googi
Ontario
Post Number: 47
the Bin process where I have to turn on the receiver and hit download the same time the green LED turns on
Username: Millertime001
Post Number: 11
I have the exact same problem Googi. My reciever worked for a month on old bin and only for a couple hours on new one. Now only green light appears on front like yours. I also use the loader from extrememicro website so I assume we bought our recievers at same place.
Username: Googi
Ontario
Post Number: 50
eBay?
Username: Lklives
Post Number: 3249
when U say green light....is it dashing across the screen -------...if so thats a simple nite rider kights fix!
Post Number: 12
Yep..Ebay
Username: Lklives
Post Number: 3256
Ebay is the biggest seller of clones..very hard to tell apart..
Username: Googi
Ontario
Post Number: 51
nope it's on the front of the unit's LCD pannel, it doesn't output any video onto a tv...ext
Username: Lklives
Post Number: 3258
Jtag...sorry!
Post Number: 8
Where do I find instruction to Jtag? I have tryed everything I had to make a serial cable because I could not find a null modem that crossed on #2 and #3. Didn't work! So I will try this Jtag and if that doesent work I have a Pansat 3500s for sale cheap hardly used lol! Any help is great thanks!
Username: Googi
Ontario
Post Number: 52
but My Pansat 3500s has a card reader and an SD port also with one of those shiny holographic stickers! could it be a clone?!
Post Number: 9
Mine too! It has an SD slot and the sticker. I did buy it off Ebay.
TIme to jtag
Post Number: 10
Really I didn't ask if I had to Jtag I asked for some instruction !
Username: Slimmaz
eva can u tell me the procedures for the GTRom loader i have no idea how to download it, i am newbie thanks
Username: Wakenbake
Post Number: 176
join at future-fta.info (free)
download 2 zip files
1-bl version 272
2 pansat epg update...
unzip both,
use loader included in epg update to put bl 272 on 2700a
Puerto Rico
Post Number: 862
Leticia: download both programs the latest gtloader and the bin to fix, unzip both program in your pc, and follow the instruction for run the bin, already posted.
Username: Slimmaz
Puerto Rico
Post Number: 863
For jtag manual go to dss***tester.com and download.
Username: Abu
Arlington, Va
Usa
hey guys i new with program and i have pansat 3500sd and i dont know what to do and i wanna to program that reciever any advice, please.
Username: Abu
Arlington, Va
Usa
hey guys i new with program and i have pansat 3500sd and i dont know what to do and i wanna to program that reciever.Lk any advice, plse.
Username: Wakenbake
Post Number: 177
doo,
1-bl version 252
unzip both,
use loader included in epg update to put bl 252 on 3500
Username: Wakenbake
Post Number: 178
pansat 3500
file bl 352
Username: Abu
Arlington, Va
Usa
Wakenbake which site plse thanks.
Username: Wakenbake
Post Number: 179
www.future-fta.info (free)
Post Number: 15
To googi and sledneck...
I also have the sd card slot and the holographic sticker...It seems like a genuine unit but I can't be sure. Did you 2 buy yours from extreme micro on ebay too?
Let me know if you get yours working..Thanks
Post Number: 16
On dss***tester is the J-Tag instructions are for a 2500. Will this also work for a 3500s?
Assuming my 3500s is not a clone, how/why did it get "zapped" after working only a couple hours on the new bin?
Username: Dixon_butz
New york, New york
United states
Post Number: 8
You have to load the latest boot file for the pansat 3500. Turn the back switch off then on then flash it with the factory bin.
Username: Moreno36
Phoenix, Arizona
Usa
eva nopuedo aser manual poner las keys del pansat2500
Username: Googi
Ontario
Post Number: 53
Millertime,
yea I got mine from extrememicro off of eBay too, and the extrememicro guy told you that if you need files go to his site and get the latest updates/email him, right?
well if you, sledneck and I got it from the same kind of bid then the item description reads :
"Genuine Pansat 3500s FTA Satellite TV Receiver Kit New In Box."
so I guess it is a real unit, but we can always ask.
clones don't have the sd/card port and a holographic sticker do they?
Username: Aaron3391
hi i am a newbie at this whole thing. i downloaded a file off http://dsstester*com/files.php?cat=14 file current ppv blackout fix. and my panset 3500 will not do any thing. all it says on the panset is b - 70 someone told me i had to flush the system. how do you do that and what happen to it? is there any way i can pervent that?
Username: Sergio20057
Mo
hello all i have pansat 3500sd i need the BIN or what i need help please
Puerto Rico
Post Number: 911
download the bin at dss**tester.com
Username: Dixon_buts
Moon Base Alpha 1, Red Square
Mars
Post Number: 15
Didn't i already answer this? Load the latest boot file. That should give you nightrider lights then load the factory bin then the latest bin. You don't need to jtag 95 percent of the time if you have any lights on the front.
Puerto Rico
Post Number: 912
Pansat Files » New Pansat 3500 BIN.Fix 2June ECM
This is the newest bin for pansat 3500.It works fine with autoroll.
Date: 11/06/2006 - View Full Info - Downloads: 641 - Download New Pansat 3500 BIN.Fix 2June ECM (768KB) http://www.dss***tester.com/files.php?cat=14
ps remove ***
FIX pansat 3500
press FACTORY SETTING then press SET DEFAULT KEY
Date: 05/02/2006 • Views: 2333 • Downloads: 1507 • Rating: 3.67 (6 Votes) http://www.dss***tester.com/details.php?file=2873500S.zip
3 files in 1 for the Pansat 3500..factory bin 050620-108,Gtrom updater 3.36,channel editor 187 http://www.dss***tester.com/search.php?query=pansat%203500%20factory%20bin&page=2
Username: Sowhatsowhat
I have a new 3500 and after loading the new bin, I got nothing. Then I reloaded and nothing. Nothing for a third time. Last time I loaded the same new bin that everyone is using, and then hit "factory settings" on the main menu. Selected the Echo 7 and 8, ran the scan on both, got tv. Try it, however if you are not even getting the regular menu screen, this is not going work for you.
Username: Gaintman
I have a 3500 and need a bin can someone help me i am new at this.
Username: Hotrod1
I have loaded the latest bin on my 3500SD and haven't had any luck thus far. Just canadian radio stations of Echo 7 and 8. I'm on satellite 110. Any suggestions?
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > Pansat 3500s will not turn on [ « Previous ] [ Next » ]
