Home > Message Board > Home Video > TV Basics > Archive through August 01, 2006 > TV NO SOUND
Author Thread: TV NO SOUND
Username: Starlabella
Hello,
Much like some other people on here, i have a question about my tv. Its an RCA purchased just this last november. The sound works when i use the dvd player, the picture is fine even when just in regular tv mode (i have cable tv) but there is no sound when just watching tv. i dont understand this. i even got new red/white/yellow cords- didnt help. the cable tech didnt even understand it. Any ideas??
Thank you!
amandastarla@verizon.net
Username: Formerly_fx
Dallas, Tx
Post Number: 107
It sounds like an internal setting within your cable box. Please post the manufacturer and model of your cable box and perhaps I can help you with the correct settings.
xvxvxvx
Thank you for your help- however i do not have a cable box, i just have a very basic cable connection (like 14 channels) basically to make them come in. I really cant figure all this out.....seems rather odd. Thanks a lot tho!
Dallas, Tx
Post Number: 113
Amanda,
Now I am really confused. When you mentioned that you purchased a new set of composite RCA connection cables I had to assume that you were connecting these to a cable box. What device are you possibly connecting these cables to that you think might have cured your audio problem?
Don't you just have the coax cable connected directly from the wall outlet to your TV? Is this a problem that just recently began? I think you are leaving out some key information here.
xvxvxvx
Username: Cableguy
Deep in the ...
U.S.
Post Number: 767
Scoob....it's possible the SAP is turned on, but I'm waiting to hear what is connected like you are
Amanda~ can you verify the path your cable takes to get to your TV?
Home > Message Board > Home Video > TV Basics > Archive through August 01, 2006 > TV NO SOUND [ « Previous ] [ Next » ]
