Home > Message Board > Home Video > DVD Players > Archive through July 29, 2006 > Unable to play DVD+/- RW,R in mustek ...
Author Thread: Unable to play DVD+/- RW,R in mustek Pl607
Username: Methealtruist
I have a mustek DVD PL607 player, according to specifications it should play DVD+/-RW and DVD+/-R, but when i put those discs it says "Wrong Disc". What to do
Username: Samijubal
Post Number: 2657
Are the discs finalized?
Yes...all the discs are finalized.
Username: Samijubal
Post Number: 2659
What were they burned on?
On LG dvd burner...with Nero software
Username: Samijubal
Post Number: 2662
I had problems with people not being able to play LG burned discs. I bought an NEC burner and in around 4000 burns, nobody has ever had any problems with the discs. Nero isn't the best burning software for sure. What brand of discs are you using?
I am using Sony DVD+/-RW and R.
Username: Samijubal
Post Number: 2696
Sony doesn't make their own discs, so it's hard to know how good the discs are. You can get the media code with DVD Decrypter, Nero, DVDInfoPro, that should tell you who actually made the discs. If you have any 8x DVD-R Sony discs that say made in Japan on the spindles, they should be TY, the best discs made.
Home > Message Board > Home Video > DVD Players > Archive through July 29, 2006 > Unable to play DVD+/- RW,R in mustek ... [ « Previous ] [ Next » ]
