Home > Message Board > Home Video > DVD Recorders > Archive through May 29, 2006 > Panasonic dvd-r disks
Author Thread: Panasonic dvd-r disks
Username: Khcpopi
I bought panasonic dvd-r disks which are labelled as 1-8x. The Toshiba dr4 stand-alone recorder will not accept this disk. Is it because of the 1-8 range? If the recorder doesn't like 16x, should I look for disks that are labelled as 8x only? Thank you in advance.
Username: Samijubal
Post Number: 2632
All 8x discs are 1-8x. You should be able to use up to 8x discs in a standalone. Burners usually tend to like some media and dislike others. The Toshiba may just not like the Panasonic discs, or the recorder may be defective.
Home > Message Board > Home Video > DVD Recorders > Archive through May 29, 2006 > Panasonic dvd-r disks [ « Previous ] [ Next » ]
