Thread: Sony GXD RDR 500 recording probs help ! |
New member Username: Dontbuysony
Post Number: 1 Registered: May-06
| Posted on Wednesday, May 24, 2006 - 08:24 am: |
Please can anyone shed any light on this problem, my (replaced under warranty, but with a b****y refurbished machine) DVDR has stopped recording/formatting and playing certain discs...comes up with 'error C1300... the disc is dirty' This happens even with brand new out of the packet quality discs. can I do anything to fix this problem myself or will it be a hand in the pocket job ? |
Gold Member Username: Samijubal
Post Number: 2624 Registered: Jul-04
| Posted on Wednesday, May 24, 2006 - 10:48 am: |
What brand and speed are the discs? Some standalones don't like 16x discs. |
Post Number: 2 Registered: May-06
| Posted on Thursday, May 25, 2006 - 02:56 am: |
I've been using Sony and Verbatim DVD+RW, not had a problem with them for months, but the machine now says every disc I insert needs cleaning, I phoned the Sony 'helpline' (a contradiction in terms !) and was told to use a cleaning disc, but having read the manual, it's not recommended for this model. Should I risk it and use a cleaning disc ? What's really p'd me off about this is that the original unit, bought new from Curry's developed a fault and was replaced by them as a straight swap, for what I believed to be another new machine, but when this one started throwing a wobbly, I looked for the serial number on the back and found a discrete 'refurbished' sticker !! now of course, they don't want to know about it !! |
Post Number: 2629 Registered: Jul-04
| Posted on Thursday, May 25, 2006 - 09:52 am: |
A cleaning disc will work sometimes. If you smoke the lens gets dirty faster. I've seen a lot of complaints about Sony recorders, you're not alone. |
