Thread: HDTV Question |
New member Username: Rts_rt
Post Number: 1 Registered: May-06
| Posted on Wednesday, May 17, 2006 - 06:42 pm: |
Sorry, I'm sure that this has been asked 1000 times but $2000+ is alot of money for me. If I have cablevision IO and they have a HDTV cable box, then I don't need to spend the extra $$ for a HDTV with the astc tuner I can just get an HD READY TV. Right? Thanks |
Post Number: 2 Registered: May-06
| Posted on Wednesday, May 17, 2006 - 06:44 pm: |
like the Panisonic TH-42PHD8UK ? Thanks again |
Silver Member Username: John_s
Columbus,
Ohio
US
Post Number: 942 Registered: Feb-04
| Posted on Sunday, May 21, 2006 - 02:20 pm: |
...then I don't need to spend the extra $$ for a HDTV with the astc tuner I can just get an HD READY TV. Yes, but I would look a little harder for a deal on a display with a minimum 1280 X 720 resolution, rather than this Panasonic's 1024 X 768. 42" is not huge these days, but it is big enough that you might see the difference.
Post Number: 3 Registered: May-06
| Posted on Sunday, May 21, 2006 - 02:46 pm: |
Thanks, John |
