Home > Message Board > Home Video > DVD Recorders > Archive through May 29, 2006 > Need help hooking up DVD recorder
Author Thread: Need help hooking up DVD recorder
Username: Parkerclay
Monroe, LA
I need helping hooking up my DVD/VCR recorder to my TV and cable box. Right now I have TV going into “cable out” on my cable box. I have “cable in” on my cable box going into my splitter. My splitter also connects to the cable in from the wall and the third prong goes into the power adaptor. How do I hook my VCR/DVD recorder into this setup?
Username: Samijubal
Post Number: 2576
If the box has s-video or RCAs, connect them to the recorder and set the recorder on line.
Monroe, LA
What confuses me is the splitter. Right now, 1 input is from the AC adaptor, 1 is from the incoming cable (wall) and the 3rd goes into the 'cable in' part of the cable box. Which one of these need to stay intact?
Thanks!
Username: Samijubal
Post Number: 2578
If you use s-video or RCAs, you don't need to change anything with the coax to record from the box. The cable into the box needs to stay there.
Monroe, LA
I do what you said but I can't change channels on my VCR/DVD recorder. When I attempt to play a movie, it become all blurry. What am I doing wrong?
Thanks & happy mothers day!
Username: Samijubal
Post Number: 2583
You can only get analog channels on the recorder, digital channels have to be done on the box. If you want to get analog channels on the recorder, split the incoming cable to the box and recorder. How is the recorder connected? It should be connected with, in order of preference, the triple components, s-video, RCAs.
Monroe, LA
I am trying AF and components.
My cable box has this setup:
OUT 1 OUT 2
Pr o o o
Pb o o o
o o o
Video Audio Video
y/x Out
My VCR/DVD Recorder looks like this:
Component Video Out
Y Pb Pr
o o o
o o o
R Audio L Video
and
DVD/VHS Common Out
Audio Video
o o o
o o o
R Audio L Video
Username: Samijubal
Post Number: 2585
Don't use the RF for recording from the box, use s-video or RCAs. To record analog channels, split the incoming cable to the box and recorder. If the TV has component inputs, use those for the DVD. You'll have to connect the VCR seperate from the DVD if using the components.
Home > Message Board > Home Video > DVD Recorders > Archive through May 29, 2006 > Need help hooking up DVD recorder [ « Previous ] [ Next » ]
