Home > Message Board > Home Video > HDTV Reception > Archive through November 02, 2006 > SONY KV32HS510 TV randomly switching ...
Author Thread: SONY KV32HS510 TV randomly switching to 16x9
Username: Media_man
Denver, CO
I have Comcast cable with a DCT6200/2005 using the component inputs on my TV. Two days ago my SONY KV32HS510 began switching at random between 4x3 and 16x9. I unplugged the cable drop from the DCT and put it directly into the RF input on my TV. It works fine that way but I don't get the Digital Cable channels including the HD channels. Anyone else here heard of this happening? I am at my wits end with Comcast so I thought I would try this forum first.
Username: Ehdmi
Post Number: 28
I think the controller IC is not functioning properly. This could be a software corruption or a hardware defect.
Do a hard reset and see if that will remove the program advancement.
HARD RESET: Merely unplug the power cord for 4 hours. It will restore everything to factory preset conditions. Then do to the OSD and reset all the feature functions to your preferences.
If that does not solve the problem, yes, you should take it to a Sony authorized shop and let them repair it. This kind of repair should not be expensive or life threatening!
Keith
http://www.eHDMI.com
Home > Message Board > Home Video > HDTV Reception > Archive through November 02, 2006 > SONY KV32HS510 TV randomly switching ... [ « Previous ] [ Next » ]
