Home > Message Board > Home Video > TV Basics > Archive through May 15, 2006 > Toshiba Projection TV
Author Thread: Toshiba Projection TV
Username: Rmccain
I have a TP50G90 projection TV that today would not come on. I turned off the TV and my son asked to turn it on about two minutes after and the Power lights flashes. Any suggestions?
Username: Boyce
Post Number: 64
Did you check the light bulb
Username: Rmccain
Light bulb? Please explain.
Username: Dlp_dude
Edmonton, Alberta
It's the bulb! As you face the TV on the left hand side is the bulb housing. Open it (with the TV unplugged) and you will find that the bulb is blown.
Username: Rmccain
HELP! There is nothing on the left hand side on my TV however at the bottom portion of the TV there is a section where there are set of three tubes (are these your bulb?) but neither looked blown. Maybe since my Toshiba Projection TV is a model TP50G90 its different.
Home > Message Board > Home Video > TV Basics > Archive through May 15, 2006 > Toshiba Projection TV [ « Previous ] [ Next » ]
