Thread: Need help with TruTech TT1620 |
New member Username: Becoverbeck
Post Number: 1 Registered: May-06
| Posted on Wednesday, May 03, 2006 - 12:16 am: |
I just got the TruTech, I have a Charter Digital Cable box, and an older GE Tv without AV inputs. There are, however, AV inputs on my digital cable box. I have everything hooked up with the exception of the 3AV connectors, because when I try it doesn't work. Does anyone know how to set this up so I can actually use my birthday present? PLEASE! Thanks in advance. |
New member Username: Jraffield
Post Number: 1 Registered: Jun-06
| Posted on Thursday, June 15, 2006 - 09:38 pm: |
I had to get an RF modulator to make my TruTech work with my older TV. Hook up the 3 connectors (red, white, yellow) from the modulator to the TruTech. Hook short coax cable from modulator to cable box, another from cable box to TV. Outside cable hooks to cable box also. Sorry for the layman's terms. I'm new at this. By the way, my TruTech remote doesn't work at all. I've changed the battery, but it doesn't even light up. Do you happen to know the code so that I can program it to a Universal remote? Thanks. |
