Home > Message Board > Home Video > HDTV Reception > Archive through November 02, 2006 > New HD problem (i think)- need help...
Author Thread: New HD problem (i think)- need help
Username: 23tg
I just bought the new sony 50" wega sxrd projection tv (kds-r50xbr1), I hooked up the HD via component cable (waiting for comcast to fix my DVI connection). The picture is great except for intermittent waves that are barely noticeable but annoying once you see them. I assume this either has to do with signal strength or interference from something. It reminds me of a slow refresh rate on my computer monitor. Any help appreciated.
Username: Wanabtech
Post Number: 27
I saw a Sony ( don't remember mdl # ) a couple of weeks ago. It was doing the same thing as you're mentioning. It was almost like humbars. I disco'd all equipment, even the coax, and the tv still had it. The customer mentioned that when she bought it, the floor model was doing the same thing. They told her it was their substandard feed. hmmm.....
Username: Ehdmi
Post Number: 26
I would try a different cable, perhaps a DVI or HDMI. Try to borrow one from a friend first if possible.
Keith
http://www.eHDMI.com
Home > Message Board > Home Video > HDTV Reception > Archive through November 02, 2006 > New HD problem (i think)- need help... [ « Previous ] [ Next » ]
