Thread: How to copy protected VHS to DVD with my DVD Recorder |
New member Username: July
Post Number: 1 Registered: Apr-06
| Posted on Thursday, April 27, 2006 - 10:36 am: |
Hi. I have Pioneer DVR-310 DVD Recorder and a lot of Disney Videos. I want to transfer them to DVD but unfortunatly I can't do it as my recorder says "Copyrighted Material" What can I do against it? Thank you |
Gold Member Username: Samijubal
Post Number: 2540 Registered: Jul-04
| Posted on Friday, April 28, 2006 - 11:04 am: |
You can get a stabilizer for less than half the price of that. Do a search for digital video stabilizer, or look on ebay. |
Post Number: 2557 Registered: Jul-04
| Posted on Wednesday, May 03, 2006 - 01:25 pm: |
They work fine, I've been using one for about 15 years. There's been a lot more complaints about the Red Pro than the $20 stabilizers. |
New member Username: Cruzer
Post Number: 1 Registered: May-06
| Posted on Wednesday, May 03, 2006 - 11:39 pm: |
Just signed up today. and I have a question I also want to archive my vhs collection to dvd, I have a dvd recorder / vcr combo. I have archived some vhs tapes over to dvd. However some movies won't let me. I know that I have to get a decoder (maybe a sima ct-2??). But the real question is Do I have to get seperate units, vcr, dvd recorder, and a decoder or will my dvd recorder/vcr combo plus a decoder work??? The vcr / dvd recorder model that I have is a Zenith model ZRY-316, if thats helps any |
Post Number: 2558 Registered: Jul-04
| Posted on Thursday, May 04, 2006 - 01:08 pm: |
You will need a seperate VCR so you can connect a stabilizer between the VHS and DVD. |
Post Number: 2 Registered: May-06
| Posted on Thursday, May 04, 2006 - 10:21 pm: |
so all I have to do is purchace a video decoder and hook up the unit to the vcr / dvd recorder combo and I will be good to go? |
Post Number: 2560 Registered: Jul-04
| Posted on Friday, May 05, 2006 - 01:10 pm: |
If you've got a combo, you'll need a stabilizer and a seperate VCR. There's no way to connect a stabilizer between the VHS and DVD on a combo. |
Post Number: 3 Registered: May-06
| Posted on Friday, May 05, 2006 - 09:02 pm: |
YOU THE MAN Mr. Massey. Thanks for the heads up. I was a bit confused on the seperate vcr and the combo . I'll purchase the stabilizer, set it up and let you know how it turned out wish me luck Thanks again. |
New member Username: Guagua
Post Number: 1 Registered: Dec-07
| Posted on Tuesday, December 18, 2007 - 09:49 pm: |
when i try to record a vhs on my dvr-310 pioneer dvd recorder, it only reproduces audio, but there are no signs of video. But connected to the TV works fine. Is there anything I could do? Does the VCR plus+ function has anything to do with it? |
Post Number: 3664 Registered: Jul-04
| Posted on Wednesday, December 19, 2007 - 10:34 am: |
Connect the VHS to the DVD with RCA cables and set the DVD on whatever input you used. |
