Thread: Code to make dvd play burnt discs |
New member Username: Michellebelle
Post Number: 1 Registered: Apr-06
| Posted on Sunday, April 02, 2006 - 04:58 am: |
I have a LG V8824W and I want to play burnt dvds...but it doesnt work. is there a code that I can enter to make it play burnt dvds? cheers for the help. -michelle xxx |
Gold Member Username: Samijubal
Post Number: 2483 Registered: Jul-04
| Posted on Sunday, April 02, 2006 - 03:14 pm: |
No, try better quality discs or another format, if you're using + discs try - discs or vice versa. |
New member Username: Jeff10d
Post Number: 4 Registered: Apr-06
| Posted on Thursday, April 06, 2006 - 06:01 pm: |
I only have problems like that when running through a VCR. |
Post Number: 6 Registered: Apr-06
| Posted on Thursday, April 06, 2006 - 06:57 pm: |
oops, misread the question |
