Home > Message Board > Home Video > Projectors > Replacement phillips 6000 hr lamp bul...
Author Thread: Replacement phillips 6000 hr lamp bulb for epson 5550c
Username: Twharley
iam looling for the number for a phillips replacement 6000 hour bulb for a epson 5550c i saw a listing on ebay where you could replace the bulb only in the old epson bulb assembly the original part number of epson is elplp06 this is a more cost efficiant way to upgrade and have a lamp that lasts 6000 hours instead od 2000 hours can any one help thanks tony w
Relevant Product Info
Username: Carozoynarizota
Tony did you get any info?
I am searching at google but nothing.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > Projectors > Replacement phillips 6000 hr lamp bul... [ « Previous ] [ Next » ]
