Thread: Record On Demand to DVD recorder? |
New member Username: Lissac67
Post Number: 3 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 08:58 pm: |
Does anyone know if it is possible and how to do it? All I get is a very snowy picture. Can you tell me how to hook it all up? Thanks! |
Bronze Member Username: Mofoknows
Post Number: 19 Registered: Mar-06
| Posted on Monday, March 27, 2006 - 12:04 pm: |
Start with the manuals. Since you provide nothing by way of equipment type, no one can provide you with a useful response. There are some good contributors in this forum, but to the best of my knowledge, no one is clairvoyant. |
Post Number: 5 Registered: Mar-06
| Posted on Monday, March 27, 2006 - 12:53 pm: |
OK! Well, I have a Panasonic ES20 DVD recorder, a Motorolla digital cable box that does NOT have the DVR function, and a Sony Wega TV with numerous means to hook things up to it. The cable box has one set of plugs for the Audio and Video, and of course the coxial cable, but nothing as far as S-Video or additional audio or video outlets. Right now I have the cable from the wall to the cable box, then to the DVD recorder, then to the TV. This is what the tech support told me to do. In order to watch On Demand we have to put it on channel 001. My DVD recorder will not let me schedule anything on channel 001, so that is not an option. Would it better to hook the cable to the cable DVD recorder, then the cable box and TV? Thanks in advanced! |
Gold Member Username: Samijubal
Post Number: 2485 Registered: Jul-04
| Posted on Sunday, April 02, 2006 - 04:40 pm: |
Connect the box to the recorder with RCAs, not coax, and set the recorder on whatever input you used. |
