Home > Message Board > Home Video > DVD Players > Archive through July 29, 2006 > Unlocking philips dvp 3005
Author Thread: Unlocking philips dvp 3005
Username: Marky_2005
how do i unlock the region code for the philips DVP 3005 cheers
Username: Zebedee1
DVP3005 / DVP5100
Press system menu on remote control
Go to preference settings
Press 1,3,5,5,6,6
Use Up and Down keys to select 0 and press OK
Press system menu on remote to exit
Username: Graemeb
Tried that but the preference option isn't allowed - it won't go there, keeps skipping over
any ideas?
Username: Minniemouse1928
Hi, I managed to do this a while ago, do you still have your instruction manual (i have lost mine) because there was something i read in there which helped me to get onto preferences..... Can you let me know what it says when you read it? Thanks.
Username: Zebedee1
Instructions read:-
Press stop square twice to stop playback (if any) then press SYSTEM MENU
Press <> to select ' preference page' icon
Press OK to confirm
Does this help??
Username: Zebedee1
Yes press STOP twice then, press SYSTEM MENU.
Press > repeatedly to select (Pref Page)
Good luck
Home > Message Board > Home Video > DVD Players > Archive through July 29, 2006 > Unlocking philips dvp 3005 [ « Previous ] [ Next » ]
