Thread: NTSC/ATSC/QAM |
New member Username: Crestapre
Post Number: 4 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 09:30 am: |
What is the difference? NTSC is analog ATSC is digital QAM same as ATSC but newer? |
Bronze Member Username: Formerly_fx
Post Number: 12 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 10:37 am: |
Google is your friend: http://en.wikipedia.org/wiki/ATSC xvxvxvx |
Post Number: 5 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 11:00 am: |
Scoob, nice link but a bit technical on some parts esp QAM. It says that ATSC tunes OTA signals into the HD relm. Does it tune (modulate) the digital signals via cable input? When I connect Comcast direct to my HDTV cable input not the OTA input am I using ATSC or NTSC tuning? it looks like I am getting HD via this setup. |
Post Number: 15 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 02:31 pm: |
"It says that ATSC tunes OTA signals into the HD relm. Does it tune (modulate) the digital signals via cable input? " No that is done by a QAM tuner. "When I connect Comcast direct to my HDTV cable input not the OTA input am I using ATSC or NTSC tuning? it looks like I am getting HD via this setup." If it is HD then neither, as above it would be the internal QAM tuner in your display. If not really HD then it would be the NTSC tuner but it will never be the ATSC tuner via a cable connection. xvxvxvx
Post Number: 6 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 02:52 pm: |
Could the NTSC tuner produce picture that rivels HD via a cable connection on a HD channel? I wouldn't think so. I can't really tell the difference when switching inputs between the HDMI from STB and straight cable connection on HD channel. The TV is a Samsung DLP HLR-5067W it mentions ATSC/NTSC tuner and Digital Cable Ready Tuner but nothing about QAM. http://www.samsung.com/Products/TV/DLPTV/HLR5067WAXXAA.asp Comcast is installing a CC this weekend. I can't wait to see what this will do! Scoob, Thanks for your help with this.
Post Number: 16 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 06:12 pm: |
"Could the NTSC tuner produce picture that rivels HD via a cable connection on a HD channel? I wouldn't think so. " No and not to be mean but many people on these forums can't tell the difference in the first place. "Comcast is installing a CC this weekend. I can't wait to see what this will do! " It shouldn't do anything differently other than remvove your ability to view Tv Guide data, eliminate any pay per view and on demand movie capability but allow the viewing of any currently scrambled HD channels you are willing to pay for. xvxvxvx |
