Thread: Need help with the Sima CT-2 |
New member Username: Arielsgrotto
Freenewark,
California
United States
Post Number: 1 Registered: Mar-06
| Posted on Wednesday, March 15, 2006 - 03:00 am: |
hey everyone, i have a panasonic DVD recorder not sure which model and I have the Sima CT-2 enhancer, it worked perfectly for a 1 and half, I had to disconnect everything for a house remodel and when I went to connect it all back together it doesnt work as well. I have a picture from the DVD but No sound, I have tried rearranging the Red, Yellow White cords got new ones and all that good stuff. I am so frustared could someone help PLEASE |
Gold Member Username: Samijubal
Post Number: 2437 Registered: Jul-04
| Posted on Wednesday, March 15, 2006 - 11:48 am: |
Connect RCAs from whatever you're playing on to one of the DVD recorder inputs and set the recorder on whatever input you used. The stabilizer goes on the video cable between the player and recorder. The audio cables connect straight from player to recorder. Make sure the audio and video cables are both connected to out on the player and the same input on the recorder. |
