Thread: HELP! LG V181 DVD/Video Combo |
New member Username: Vjb78
Melbourne
Australia
Post Number: 1 Registered: Mar-06
| Posted on Tuesday, March 14, 2006 - 07:29 pm: |
Hi! Can anyone PLEASE help??? I just bought a LG DVD/Video combo V181 and the guys at JB Hi Fi no longer hand out the codes to make the players region free. I have tried the 7 '0' code and to no avail. CAN ANYONE HELP?? Thanks. |
New member Username: Frenik
| Posted on Thursday, March 23, 2006 - 10:53 am: |
Does this one work? Press STOP (I think this is optional) Press PAUSE Enter code 314159 Enter Region Code (0 for all) Press PAUSE Turn power off then on. |
Post Number: 2 Registered: Mar-06
| Posted on Thursday, March 23, 2006 - 10:55 am: |
Also, could you tell me if your V181 has an OPTICAL digital output? All specs on the web says it has both optical and coax, but the manual I downloaded for it from LG site shows only having coax. |
New member Username: Siddela
| Posted on Friday, March 24, 2006 - 10:41 pm: |
Hi, The LG V181 doesn't have an optical out. The '314159 hack' does work with this model. I tried it several time before it worked though. make sure you unplug the power, then power on without a disc in. |
New member Username: Dr_funkenstein
| Posted on Thursday, March 30, 2006 - 06:17 am: |
Hi Andrew, I bought same model dvd/vcr combo than you did. However the hack didnt work on mine and i am sure its because i didnt do it properly. I am not sure at what point boxes open to put the number in or how its supposed to work. Please help. |
Melbourne
Australia
| Posted on Thursday, March 30, 2006 - 03:59 pm: |
Hi, I figured it by a complete fluke. With the cd tray open, hit 0000 then a screen will come up where u enter the region code - make it 0 then you press pause and it's done!! I found this has worked for one of my other LG dvd players as well. Hope this helps. |
Post Number: 3 Registered: Mar-06
| Posted on Thursday, March 30, 2006 - 06:55 pm: |
I've since gotten my V181 and tried the 314159 hack on this model (previously only used it on a different model) With the player in DVD mode, no discs in the player, just: Press PAUSE on the remote. Enter code 314159 on the remote. Should now be on screen asking you which region you want to set (0-6). Press 0 for all regions. Press PAUSE on remote again. Thats all it took on mine, after that could play all regions, didn't need to restart player. |
| Posted on Friday, March 31, 2006 - 03:42 am: |
Frenik.. that was awesome! Thanks so much! It worked fantastic! It is now region free! Vaughan, thanks for your reply! I didnt get to try yours but thanks for your response. I LOVE YOU GUYS!!!! |
New member Username: Drjasper
Perth,
Tasmania
Australia
Post Number: 1 Registered: Apr-06
| Posted on Monday, April 17, 2006 - 01:41 am: |
worked well for me too. I just picked one of these up this morning. The only thing I'd add is that for me I had to open the cd door like Ted |
