Thread: Mitsubishi WD52628 or Sony KDS R60XR1? |
New member Username: Hawkssr
Mesa,
Az
Post Number: 2 Registered: Mar-06
| Posted on Tuesday, March 14, 2006 - 07:16 pm: |
I am considering buying a Mitsubishi WD 52628 DPL. Has anyone got this model and how well do you like it. I have seen good reviews on the Sony KDS R60XR1 but have been told that replacing a bulb in it was very expensive whereas it is not for the Mitsubishi. Thank you. |
Silver Member Username: Xdrummer03
Tenessee
Post Number: 284 Registered: Jul-05
| Posted on Wednesday, March 15, 2006 - 03:35 am: |
There not too high for the Sony.Especially since there rated @ 8,000 hours.If you want a nice DLP for the price get If you have the 60SXRD in mind the go ahead and scoop one up.Bigger screen,way more contrast and 1080p set. |
Mesa,
Az
Post Number: 3 Registered: Mar-06
| Posted on Wednesday, March 15, 2006 - 12:28 pm: |
Thanks drummer. Does this sony have pip, from what i've been told the mitsubishi does. |
Tenessee
Post Number: 286 Registered: Jul-05
| Posted on Thursday, March 16, 2006 - 03:35 pm: |
Yes the Sony has PiP. |
New member Username: Chasp
Tampa,
FL
Post Number: 4 Registered: Nov-05
| Posted on Friday, March 17, 2006 - 07:39 pm: |
I have the Mits 52628, all i can say is it's near perfect! Chas |
Mesa,
Az
Post Number: 4 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 09:07 pm: |
Thanks for your input Chas. |
Bronze Member Username: Johnd7
Post Number: 15 Registered: Feb-06
| Posted on Friday, March 17, 2006 - 09:53 pm: |
How far are you going to be sitting from the screen? Keep in mind that is an important consideration. I just got the 50in. Sony SXBR and 10 feet away is perfect. |
Tampa,
FL
Post Number: 5 Registered: Nov-05
| Posted on Saturday, March 18, 2006 - 08:07 am: |
I have had my Mits 52628 since Nov of 05, and not one problem so far! It replaced a Loewe 38" Aconda. The black levels are very good on the Mits, with over the air HDTV , and with my Pioneer DV-59 hooked up with HDMI the pic will just blow you away! I never thought the Mits would compare with my Loewe, but i think the Mits is a step better. I will have Craig R do a calibration on the Mits this month. Chas |
New member Username: Sendsley
Post Number: 1 Registered: Mar-06
| Posted on Monday, March 27, 2006 - 10:08 am: |
Looking at the Mits 52628 at Nebraska Furn Mart over the weekend. The "Stretch 480i" picture with a cable tv input look really bad..... Anybody have DirecTV hooked up? Does the stretch picture for non HD look good? Thanks in advance! |
