Thread: HD without Comcast STB |
New member Username: Crestapre
Post Number: 2 Registered: Mar-06
| Posted on Tuesday, March 14, 2006 - 01:51 pm: |
I've got a Samsung DLP HLR5067 configured as below: a)hooked up direct to cable input(COMP1)w/o a box using the TV tuner NTSC/ATSC b)the Comcast HD box hooked up with DVI cable to (COMP2). I see no difference between these two set ups. Am I getting HD w/o the STB? Comcast tells me that I neeed the CC to get HD w/o STB. If I ditch the STB and use the CC what is tuning the HD? |
Relevant Product Info
Post Number: 3 Registered: Mar-06
| Posted on Wednesday, March 15, 2006 - 08:27 am: |
Also I have hooked up a s-video cable to the STB on AV1 input to check foe better SD reception. This doesn't really show much improvement. Any help out there? |
New member Username: Formerly_fx
Post Number: 7 Registered: Mar-06
| Posted on Wednesday, March 15, 2006 - 04:50 pm: |
"Am I getting HD w/o the STB?" If your display has an internal QAM tuner then yes you are, I'm not going to look it up online but I imagine yours does. What Comcast really means is any scrambled (not in the clear) HD channels will require a CC or an STB in order to unscramble the protected programming. This is normally for HBO and other HD movie channels and on most systems ESPNHD and DiscoveryHD as well. xvxvxvx |
New member Username: Wfld1863
Post Number: 2 Registered: Apr-06
| Posted on Saturday, April 22, 2006 - 09:51 am: |
Does anyone know if Comcast intentionally blocks the audio on these subchannels (88-2, 101-8 etc) through the QAM tuner for protection. I had these stations (HD & non HD ) with full audio for about 10 minutes after initial scan and then it disappeared. Channels coming through on regular channels (2,4,6,32,etc) are fine. |
Bronze Member Username: Formerly_fx
Dallas,
Tx
Post Number: 77 Registered: Mar-06
| Posted on Saturday, April 22, 2006 - 10:07 am: |
Bill, I read your other post on this subject as well. No they don't do that. What good would that do? I would suspect you need either do another scan or a cable came loose or one last suggestion an audio setting was changed somewhere. xvxvxvx |
Post Number: 3 Registered: Apr-06
| Posted on Saturday, April 22, 2006 - 10:42 am: |
Scooby Thanks for responding, I've done additional scans and as far as the wire loose, the signal is coming in from a coax cable and as I said the regular channels on that input come in fine. As far as what good would it do, if someone was watching Comcast HD channels and others through their QAM tuner w/o the box, Comcast loses $$, on the rental for the box and probably programming. Some of the channels I was picking up were HBO On-Demand and PPV movies. I thought it was on the Comcast end because when I check the digital audio settings for one of these channels on my TV is states "unknown AC3" which I think represents some kind of audio codec. Anyway, thanks for responding, it's not a big deal for me because I do have a HD cable box, I was just curious what happened to the audio. |
New member Username: Watcher
Post Number: 1 Registered: Jun-06
| Posted on Thursday, June 15, 2006 - 09:53 pm: |
I currently have Comcast Digital Service with a STB for my HDTV without a built-in tuner. I just purchased a new HDTV with a built-in. Comcast is telling me I must have another box (which will add $11 to my bill) in order to receive true HD programming. If I connect the cable that is presently connected to my old non-HD TV and use no box, what HD signals will I receive, if any? |
Silver Member Username: Formerly_fx
Dallas,
Tx
Post Number: 127 Registered: Mar-06
| Posted on Thursday, June 15, 2006 - 11:21 pm: |
CONNECT IT AND SEE. xvxvxvx |
Bronze Member Username: Indianbill007
Bhilai,
Chattisgarh
India
Post Number: 15 Registered: Dec-06
| Posted on Wednesday, December 13, 2006 - 12:40 pm: |
Well I got really something good and cool in a single give away package . Online IP TV , that is satellite TV and online radio channels in a single software. http://www.artvnetworks.com Online TV Player lets you watch 2500+ free Internet TV and listen 1500+ free online radio stations on your PC. It allows watcher to watch directly into TV without having to experience the annoyances of a Web site (like slow-loading pages and pop-up ads). No additional equipment required, No Monthly Fees, No Extra Costs. Online TV Player support both Windows Media and Real Video. You can play most of stream formats in one program. It can set the screen window to any size that you want. It supports full-screen mode too. Download yourself and enjoy.!! |
New member Username: Muzicman
Post Number: 5 Registered: May-07
| Posted on Wednesday, May 16, 2007 - 01:52 pm: |
I hooked up my HDTV directly to my Comcast cable and let the TV scan for usable channels. I founnd a variety of HD channels in 5.1 for PPV and ON Demand. I think I am seeing my neighbors On Demand and PPV stations. One show was being fast forwarded and had the On Demand watermark on the lower right of the screen. The channels are odd like 94-4, 94-5, ect... |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 1174 Registered: Oct-06
| Posted on Thursday, May 17, 2007 - 09:26 pm: |
interesting If you can see more than one PPV then it is not your neighbor As far as I know you might be missing a trap or a filter that blocks certain QAM channels Cable company forgot to put it. please tell me more about it do you get premium channels as well? |
Post Number: 6 Registered: May-07
| Posted on Friday, May 18, 2007 - 10:44 am: |
I do not see any premium channels. Most of the "odd channels" like 94-8, 94-9, ect are just black. The other night, on channel 98-6, someone was watching a p*rn PPV. They would speed it up between the sex scenes and return to normal speed. You could even see the progress bar and the double right arrows during the fast forward. At the end of the show (yes, I watched it to the end), the screen went black and my TV displayed "Missing or scrambled channel". I believe I can see more than 1 of my neighbors PPV and ON Demand. Keep in mind, this is a straight connection between the coax and my TV, there is no STB. I don't really see it as a big value, as nothing on these "odd stations" are on the schedule. I do not know if Comcast made a mistake to allow this to happen, but it's reallty no big deal other than the free p*rn periodically!! |
NY
Post Number: 1184 Registered: Oct-06
| Posted on Friday, May 18, 2007 - 05:40 pm: |
That is so funny It looks like a feedback interference or tunned to someone else's frequency I bet yo it is the the guy across the street from you sharing the same hub You might get free internet if he is got that too I still think they might be a way to get more channels |
