Home > Message Board > Home Video > Projectors > PT-AE700u aspect ratio
Author Thread: PT-AE700u aspect ratio
Username: Poopy
Hi, I have a PT ae700u projector and am having trouble with the aspect ratio. I was using to only watch DVDs via the HDMI with no problems. yesterday I hooked up a DISH netork 622 HD receiver, which also was working good but was automaticcaly swicthing th aspect ratio between 16:9 and 4:3 for appropriate programming. However, after hooking this up to the Dish via HDMI, it knocked out my ability to change the aspect ratio via either the remote or through the menu settings...they are greyed out. When I hooked back up the DVD player, I now cannot change the aspect ration on these either now and the projector seems to be stuck in 16:9 mode. Again, the remote doesn't work nor does going in through the menu settings as "aspect ratio" is greyed out. The DVD settings is set to 4:3.
Any help on this would be GREATLY appreciated as I can't stand watching wide squashed images.
THANKS!!
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > Projectors > PT-AE700u aspect ratio [ « Previous ] [ Next » ]
