Home > Message Board > Home Video > Rear Projection TVs > Archive through April 25, 2006 > Newbie with Question
Author Thread: Newbie with Question
Username: Taman
NY
I don't understand what you mean by this,
"Can you get service in your area for each brand of tv you are considering? "
I though digital cable is digital cable. Also what do you think would be best for my situation??
Anyone????
T
"Respect is Everything" GTA2
Hogan 4-Life
Please check out my "Best of Both" websites,
www.sasso8893.mywebcashstore.com
www.sasso8893.mycasinopartners.com
Username: Taman
NY
Hey there, I just started researching hd tv sets. Just to give you a little info, i will be purchasing digital cable with HD and i'll also be using the set for playing my videogames. I've been checking out a view sets which include the jvc HD-52G886, the samsung HL-R5668W and the toshiba HD 52HM95. I guess my biggest dilema is whether or not to get a set with the 720 or 1080 resolution. I know 1080 is the newest techology but i've read that is has problems with fast motions. Would that be a problem for my videogames or watching sports. Also my viewing distance is about 7 feet, also i'm trying to keep my budget below 2500. I'd like stay in b/w 52 and 56 inches. I'm looking for any suggestions or comments that you can give me. Thanks in advance for responding.
T
Hogan 4-Life
Username: Taman
NY
nobody??? I just trying to figure out if 1080p is worth the $$$ if i'm going to be using it for sports and videogames. I know the new ps3 will use 1080p so does that answer my question??
Home > Message Board > Home Video > Rear Projection TVs > Archive through April 25, 2006 > Newbie with Question [ « Previous ] [ Next » ]
