Home > Message Board > Home Video > Projectors > OPTOMA MovieTime Home Theater DLP Pro...
Author Thread: OPTOMA MovieTime Home Theater DLP Projector - DV10?
Username: Agentxfile
Post Number: 55
Anyone have this OPTOMA MovieTime Home Theater DLP Projector With Built In DVD - DV10, and have any thoughts?
Please let me know.
Thanks, Joe
Relevant Product Info
Username: Scottyd
Boston, MA
Yo, I got one last week. Not a bad little unit. It has a short throw distance so it creates a large screen from a short distance. Also the recommended seating is next to or behind the unit. I have mine about 9.5 feet from a 92 inch screen - which it fills. I kind of notice a screendoor effect though. I think if I could move back 1 foot or 2 it would be a lot better. I find myself wondering if I should have gone the the optoma h31 though (You can sit in front of that projecter). Check out www.projectorcentral.com. They have calculators and every spec u can think of.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > Projectors > OPTOMA MovieTime Home Theater DLP Pro... [ « Previous ] [ Next » ]
