Home > Message Board > Home Video > VCR > Set vcr to record?
Author Thread: Set vcr to record?
mabel
i have an LGV8824W dvd/vcr combo, and saly i have lost the instruction manual, so do not know how to set the vcr to record at a certain time. if anyone can help me with this it would be greatly appriciated.
thanks
Relevant Product Info
Username: Jasmine
i have an instruction manual that i could photocopy and post to you depending on where you are in the world
but if you contact lg i'm sure they would send you a new instruciton manual
here's a brief description of vcr recording from the manual if it helps ...
press i
press left/right arrows to select REC
press ok
enter channel, date and start/end time
using right arrow to move from channel to date and from date to time
then press i twice
then press POWER to switch VCR to standby and a little clock symbol should appear in the display window
hope this helps!
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > VCR > Set vcr to record? [ « Previous ] [ Next » ]
