Home > Message Board > Home Video > Rear Projection TVs > Archive through March 02, 2006 > DIY TV repair help, im a little confused
Author Thread: DIY TV repair help, im a little confused
Username: Tweek52
Post Number: 48
Okay so i have this big ole mitsubishi tv and it doesnt turn on so i looked it up. found this.
Shutdown at power on:
1. SHUT DOWN CAUSED BY EXCESSIVE 130V SUPPLY, CHECK C914 (22 UFD 50 V) AND
C915 (220 UFD 50 V) ON THE POWER-SOUND PCB. 2. CHECK FOR SHORTED OR LEAKY
D503, PART # 264P244030 OFF PIN 5 OF IC 500 ON THE MAIN PCB
Intermittent shutdown:
1. CHECK FOR 22.5 VDC AT PIN 5 OF IC500 IF LOW CHECK D503 PART # 264P244030
ON THE MAIN PCB.
from Mitsubishi website
Robert
tvservice@xxxxxxxxxxxxx
H & H Electronics Inc
Is there anyway I would be able to fix this myself or would I have to call a guy in, and if so how much does tv repair like this cost.
Home > Message Board > Home Video > Rear Projection TVs > Archive through March 02, 2006 > DIY TV repair help, im a little confused [ « Previous ] [ Next » ]
