Thread: Trouble with finalizing |
New member Username: Bigbear
Burlington,
Vermont
Post Number: 1 Registered: Feb-06
| Posted on Monday, February 13, 2006 - 01:02 pm: |
Help please. I have been copying programs from my DVR to DVD's using a Panasonic DMR-55. I'm doing this for a friend stationed in Iraq. After spending 4 hrs copying the disk then get a message "finalize failure" ##U)**? This has happened with at least 3 disks. So any ideas what I'm doing wrong. I'm using DVD-R disks ( Memorex I think). |
Gold Member Username: Samijubal
Post Number: 2299 Registered: Jul-04
| Posted on Tuesday, February 14, 2006 - 12:10 pm: |
What speed are the discs? Stay away from 16x discs with a standalone. |
Burlington,
Vermont
Post Number: 2 Registered: Feb-06
| Posted on Tuesday, February 14, 2006 - 12:22 pm: |
As I recall they are 8X. I saw that Panasonic has a firmware upgeade for this recorder, but I'm a little apprehensive about upgrading. |
Post Number: 2300 Registered: Jul-04
| Posted on Tuesday, February 14, 2006 - 01:21 pm: |
I never had any problems using 8x discs. Memorex doesn't make their own discs and uses multiple manufacterers, so unless you have a PC burner, there's no way of knowing if they are good discs or not. Firmware updates will sometimes fix compatibility problems. |
