Home > Message Board > Home Video > DVD Recorders > Archive through May 29, 2006 > DVD Labels, to use or avoid?
Author Thread: DVD Labels, to use or avoid?
Username: Thomasm
I was wondering about sticking DVD labels on.Is this something that might cause the DVD not to play 10-20 years down the road? I've stuck labels on my CDs and they play fine 4 years later, but I don't know if any damage will occur years later.Right now I'm holding off until I can get some good advice. Would appreciate any. Do most of you use labels or avoid them?
Username: Samijubal
Post Number: 2257
Stay away from labels. DVDs spin much faster than CDs with a track that is not near as wide. Labels can throw the disc out of balance and/or warp the disc when the labels dry and shrink.
Username: Thomasm
Thanks David! I will avoid them on DVDs.
Username: Scotthall
Vancouver, BC
Post Number: 7
Is it bad for the disc or the DVD player?
Username: Samijubal
Post Number: 2510
Mostly the disc, but out of balance discs put more strain on the spindle motor from the extra vibration.
Home > Message Board > Home Video > DVD Recorders > Archive through May 29, 2006 > DVD Labels, to use or avoid? [ « Previous ] [ Next » ]
