Home > Message Board > Home Video > Rear Projection TVs > Archive through March 02, 2006 > Can someone review the samsung HL-R42...
Author Thread: Can someone review the samsung HL-R4266W DLP rear projection.
Username: Darksteve
Need to know if its better than the sony KDF-E42A10 LCD rear projection.
Username: Xdrummer03
Tenessee
Post Number: 223
Samsung will give you a more truer-to-life picture cause of a little higher contrast.DLP so cs=an handle movement very well,even si since it has a 7 segment color wheel.The Sony will give you a brighter ,sharper image(clearer).If you have fairly bright room a LCD will handle the light better and has better side angle.Though not by much but is significantly different.Bulb replacment are only $50 more for the Sony as well.Sony my pick is the Sony KDF-EA10.
Home > Message Board > Home Video > Rear Projection TVs > Archive through March 02, 2006 > Can someone review the samsung HL-R42... [ « Previous ] [ Next » ]
