Home > Message Board > Home Video > DVD Recorders > Archive through March 04, 2006 > Which dvd recorder with hard drive re...
Author Thread: Which dvd recorder with hard drive records the best in LP mode?
Aries
I have a Panasonic and the LP quality is ok but just wondering if there's any other recorder that is known to have better LP quality.
fx
If you have one of the newer Pannys (newer than the E-80 or E-85) they have increased the bitrate on LP and none on the market today are better. Some are close to the same but Panny's have the same length of time but with a lower bitrate.
xvxvxvx
Username: Samijubal
Post Number: 2242
LP sucks on any recorder. Why bother when good quality discs are 30 cents or less. It's not worth the loss of quality over a few pennies.
Home > Message Board > Home Video > DVD Recorders > Archive through March 04, 2006 > Which dvd recorder with hard drive re... [ « Previous ] [ Next » ]
