Home > Message Board > Home Video > Rear Projection TVs > Archive through March 02, 2006 > FYI HELP ME!
Author Thread: FYI HELP ME!
Username: Beewilliams
I noticed you had a problem with your Samsung freezing and displaying a black and white image. The only way to reset it was to unplug the television. Mine has developed the same issue. What was the problem and how did you solve it? Thanks in advance.
=B=
This is apparently an issue that a few people have but I never see a solution. Can anyone help?
Username: Fyi
Dallas, Texas
Post Number: 604
You have me confused with somebody else, but it sounds like a DMD controller module. Could it be heating up from a dirty cooling fan? How long in service. Under warranty?
Sorry I thought I saw a post by you on this subject, btu thanks for the reply. I bought a 2 year warranty from CC. It was just serviced like 3 weeks ago for a bad color wheel. The television is 2 years old with maybe slightly above average use. It could be the fans since it has never been cleaned in there but it is in a well ventilated area. I could try to open it and check the fans because it may be a heat issue as it normally happens after the tv has been in use a few hours.
=B=
Username: Fyi
Dallas, Texas
Post Number: 611
Oh...you should call that guy back and see what he thinks about it. He may have caused it for all we know.
Home > Message Board > Home Video > Rear Projection TVs > Archive through March 02, 2006 > FYI HELP ME! [ « Previous ] [ Next » ]
