Thread: Tv antenna question |
annonymous kirt Unregistered guest |
| Posted on Wednesday, February 01, 2006 - 08:12 pm: |
i heard if i get a tv antenna i can pick up certain local channels in HD. WHere can i pick up one of these and about how much are they. are there certain brands i should look at?? thanks a bunch |
Silver Member Username: John_s
Columbus,
Ohio
US
Post Number: 672 Registered: Feb-04
| Posted on Wednesday, February 01, 2006 - 09:30 pm: |
annonymous kirt Unregistered guest Posted on Wednesday, February 01, 2006 - 08:12 pm: -------------------------------------------------------------------------------- i heard if i get a tv antenna i can pick up certain local channels in HD. WHere can i pick up one of these and about how much are they. are there certain brands i should look at?? thanks a bunch -------------------------------------------------------------------------------- - What TV model do you have? |
Silver Member Username: Fyi
Dallas,
Texas
Post Number: 596 Registered: May-05
| Posted on Wednesday, February 01, 2006 - 09:46 pm: |
I like Winegard, but there is Channel Master and others. Even Radio Shack offers a decent VHF/UHF antenna. There's nothing special about it. It's the same old antenna that's been on roof tops for more than 50 years. http://www.solidsignal.com/antennas/?xfermeth=directg&gclid=CLD7kZvr-IICFThnOAod wleNrA http://www.winegard.com/offair/offairmain.htm http://www.radioshack.com/search/index.jsp?kwCatId=&kw=vhf%20antenna |
| Posted on Thursday, February 02, 2006 - 12:50 pm: |
i have the panasonic pt-50lcx64. will any antenna work for any tv or do i have to find a specific one? also i see VHF/UHF and VHF/UHF/HD antennas. does having the HD one matter or will i be able to pick up HD channels with just a VHF/UHF one? thanks for the help |
Dallas,
Texas
Post Number: 597 Registered: May-05
| Posted on Thursday, February 02, 2006 - 02:40 pm: |
There are no specific antennas made for a certain tv? I'll repeat! There's nothing special about it." It's the same old antenna... Don't pay more for one that says HD. It's a rip! Go to www.antennaweb.org Put in your zip code and see how far you are from your local digital stations. By an appropriate sized antenna for your distance from the towers. |
Silver Member Username: Videobruce
Buffalo ,
NY
Post Number: 106 Registered: Nov-04
| Posted on Tuesday, March 14, 2006 - 09:41 am: |
Better off with 2150. No 3rd grade color charts; http://www.2150.com/broadcast/default.asp
Columbus,
Ohio
US
Post Number: 813 Registered: Feb-04
| Posted on Tuesday, March 14, 2006 - 10:25 am: |
videobruce, now we have to know our longitude and latitude? Thanks I'll stay in the 3rd grade. |
