Thread: Cable Recommendations |
newmex999 Unregistered guest |
| Posted on Thursday, January 26, 2006 - 10:52 pm: |
OK- I am new to all this. What cables(brand)do you recommend using to connect from DVD to HDTV? Monster cables seem to be the most prevalent in the stores, however they seem overpriced. I am going to connect DVD to HDTV via component connections. |
Silver Member Username: John_s
Columbus,
Ohio
US
Post Number: 653 Registered: Feb-04
| Posted on Friday, January 27, 2006 - 08:20 am: |
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023502 &p_id=960&seq=1&format=2&style= 5 to 7 business days delivery depending on where you live. Very good quality and dirt cheap even with shipping cost. |
New member Username: Kingcurt
Oakland,
Ca
Usa
Post Number: 1 Registered: Mar-06
| Posted on Saturday, March 18, 2006 - 01:08 am: |
i have a phillips 43inch hdtv projection tv. two months ago, the blues in the color started getting out of alighment, i used the convergance to put them back in order,but a week later the same thing happened, and this time i could not get the blues to go back in alighment. now just two days ago i turned on the set and i got sound, but no picture. the set is only 3 yrs old, the model #43pp920217.any sugestions. can it be fixed for under 300 or do i plan for a replacement. |
