Thread: Help Connecting Panasonic DMR-e55 to VCR/TV |
JScott527 Unregistered guest |
| Posted on Sunday, January 08, 2006 - 09:24 pm: |
I'm planning on purchasing a DMR-e55 DVD Recorder. I have a VCR/TV mixture and a digital cable box. The only slots on the back of the TV/VC are audio/video input slots. What exactly would I need to connect them? I know next to nothing about s-cables, etc. Thanks a LOT! |
| Posted on Monday, January 09, 2006 - 02:20 pm: |
I think I got it. Thanks to this Panasonic Pictorial (thanks to google lol).. http://www.panasonic.com/consumer_electronics/dvd_recorder/dvd_connection7.asp I figured out that I need a RF Modulator along with two coaxial cables. |
| Posted on Monday, January 23, 2006 - 11:28 pm: |
I am trying to connect my DVD player recorder to my TV. I do not have a cable box but just a line. I do not know anything about hooking this up and my manual has disappeared. I would like to be able to watch TV through my DVD and record if I choose. The way I have it hooked up now we can not view the TV at all. |
Gold Member Username: Samijubal
Post Number: 2144 Registered: Jul-04
| Posted on Tuesday, January 24, 2006 - 09:38 pm: |
Connect the incoming cable to the recorder, then connect the recorder to the TV with, in order of preference, component, s-video, RCAs. If using component or s-video, you still need RCAs for audio. Autoprogram the channels on the recorder. |
