Thread: Status message randomly appears on screen with Panasonic DMR-EH50 |
| Posted on Sunday, January 08, 2006 - 11:55 am: |
Does anybody know why it does this? I'll just be watching TV, nowhere near the remote control, and all of a sudden the black box in the upper right hand corner will appear with the name and number of the channel I'm watching. Sometimes it happens once a day, sometimes it happens every five minutes or so! That's when it gets annoying... I don't want to turn off the messages completely because then they don't show up at all when I'm surfing channels, but once I pick a channel I don't need to see it anymore! Thanks for your help! |
Bronze Member Username: Paul_t
Post Number: 85 Registered: Dec-03
| Posted on Thursday, January 12, 2006 - 09:56 pm: |
I'm betting the TV Guide is kicking on and updating.... Last night my wife called me at work and said the remote was changing channels by itself, when I told her to take the remotes out of the room and it still did it I knew what it was.. Just had her move the IR Blaster away from the cable box and it stopped.. |
| Posted on Friday, January 13, 2006 - 10:42 am: |
Hi! Thanks so much for responding. The thing is, though, that I don't have a cable box, and therefore am not using the IR Blaster. The Guide seems to work fine without it, except for this one little glitch. Any other ideas? Thanks again! |
| Posted on Saturday, January 14, 2006 - 11:09 pm: |
The batteries in your remote are weak. xvxvxvx |
| Posted on Thursday, January 19, 2006 - 03:32 am: |
Go to setup screen and disable "status messages" option |
| Posted on Thursday, January 19, 2006 - 06:12 pm: |
Thanks for the responses, guys. Unfortunately fx, I replaced the batteries and it's still doing it. plinko, as I said in my first post, I'd rather not do that because then they don't show up at all, even when I'm surfing. I think I'm going to have to call the maintenance number in the instruction manual. Thanks anyway! |
New member Username: Nelson41
Post Number: 1 Registered: Feb-06
| Posted on Tuesday, February 28, 2006 - 07:24 pm: |
have recently purchased a Panasonic DMR-HE50 DVD recorder and would like to make it multi Region so that I can play my Region 1 DVDs. Could some one tell me how to do this.and is possible to up grade the hrad drive to 160g? Please advise to email nelson41@iprimus.com.au |
