Thread: Dvd hook up problem |
New member Username: Danb595
Post Number: 1 Registered: Jan-06
| Posted on Friday, January 06, 2006 - 12:35 pm: |
is there any way to hook up a dvd player to an older model tv without av jacks? |
Silver Member Username: Chitown
Post Number: 644 Registered: Apr-05
| Posted on Friday, January 06, 2006 - 01:31 pm: |
Visit your neighborhood Radio Shack. I'm sure they have some kind of converter for you. Why are you using such an old TV, when people who are getting HDTV's are practically giving away their analoge, but still much newer TV's? Take a look at Craigslist.com
| Posted on Friday, January 06, 2006 - 09:45 pm: |
I am helping my dad over the phone with his new dvd player hook up. He is getting no picture. He has sat, vcr, dvd, and tv. sat hooked to tv, dvd hooked to tv, vcr hooked to tv. but no picture for dvd player. please help di |
Gold Member Username: Samijubal
Post Number: 2078 Registered: Jul-04
| Posted on Saturday, January 07, 2006 - 12:30 pm: |
dan, you need an RF modulator. Think about buying a new TV if you plan on watching very many DVDS, the quality will be far better on a newer TV with line inputs. |
| Posted on Saturday, January 07, 2006 - 04:36 pm: |
Here is the stump-you question of the decade. No one can figure out the problem. Pertinent equipment stats: Hughes receiver Model GAEBOA Panasonic DVD/VCR combo Model 4745S Sharp TV 1997—coaxial connector only in back, 2-jack AV in front My aunt has DIRECTV. She previously had a Sony VCR and hooked it up, logically, as receiver to VCR to TV, all using only coaxial. It worked fine. I bought her the above DVD combo. Hooking it up the same way, nothing happens. The TV screen shows only static—it is not receiving the signal. Adding AV cables does not help. Tried the TV on ch. 3 and ch. 4—no difference. Finally, I bought a 3-way video connector (you know what it mean, even if I have misnamed it, I’m sure). Plugged receiver coaxial into that then coaxial into TV. Used AV connections to add DVD combo. The DVD did set up and the TV received and it was possible to watch a tape or DVD. However, since the DVD/VCR was not receiving the signal, it was impossible to tape a program. A new TV is not an option, in case that occurs to someone as the easiest solution. Would a splitter help? Will anything help? A sledge hammer, perhaps? |
