Home > Message Board > Home Video > Satellite TV > Archive through December 23, 2005 > Signal issues!!!
Author Thread: Signal issues!!!
my pansat 2700 has the right keys and is on the right birds, but just now it said no signal. i went to the installation screen and its at 29% 0 quality. I unplugged it for a couple minutes plugged it back in and TV again for about 30 seconds with good signal strength then it goes out again and back to 29% what gives? and how do i fix it? thanks
Beat_This
Are you using a switch, check the switch and see if any of the wires are loose or you have, snow,water or ice on the switch. The stupid switches are not weatherproof and if it snows on it then you loose the signal just like that. It happend to me so I had to unplug the switch and bring it in to leave it infront of the heater to dry it up. Then I bought a plastic casing for it and it so no water or anything goes in, for now it is working all fine even though lots of snow is on it.
Good luck!
Home > Message Board > Home Video > Satellite TV > Archive through December 23, 2005 > Signal issues!!! [ « Previous ] [ Next » ]
