Thread: Fortec Pin reset |
CarlosSal Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 01:33 pm: |
can anyone tell me if there's a way to reset the password pin? Thx. |
Gold Member Username: Thill1951akalk
Post Number: 1247 Registered: Oct-05
| Posted on Tuesday, December 27, 2005 - 01:52 pm: |
Upload another bin will reset the password back to 1010 or 1668.. |
Pepe Smith Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 02:10 pm: |
users why not use pansat2500a 267 bin and change your remote control |
Post Number: 1248 Registered: Oct-05
| Posted on Tuesday, December 27, 2005 - 02:18 pm: |
The true 267 bin will kill all other receivers, except genuine Pansat 2500's!..cannot use it on ANY Fortec ..there is a "267 clone safe" bin, that works on some older fortecs that is decent with autoroll too..dsscommunity forums has it,in pantec area I believe.. Safest bins for Fortecs are the 282T or the 256T (pansat bin) |
| Posted on Tuesday, December 27, 2005 - 06:01 pm: |
I dont think 267 bin kill all receivers.Ive been using that bin since 267 came until now my fortec still on working condition and no problem at all. |
