Thread: Cant get dish 119 bird on 2700 pansat |
New member Username: Kman
Post Number: 1 Registered: Dec-05
| Posted on Tuesday, December 27, 2005 - 10:20 am: |
Hey guys, I have a 2700A and I have 2 dishes hooked up to a DISEQC switch one dish is on 119 bird and other on 61.5. My problem is that I can only get one bird at a time, through the switch I can only get 61.5 and cannot get 119! I have tried replacing the switch with a new one, changed the location from 1-4, played with skew nothing seems to be working. Anyone else experienced this and were successfull debugging the problem! Thanks for the help, |
| Posted on Tuesday, December 27, 2005 - 11:45 am: |
Not sure if this is your problem but many have found that you now need to install a dummy satellite in your channel list first, then the other sats. For some reason the N2 bin wipes out the signal to the first sat in the list. |
New member Username: Humair
Post Number: 2 Registered: Dec-05
| Posted on Tuesday, December 27, 2005 - 02:39 pm: |
can some 1 help me i have fortecstar digital satellite system lifetime ultraTM Enho3 61.5 LBN type: standard LBN Local-Freq: 11250 22KHz: OFF DisEqc: 2 LBN Powre: ON TP: 12239 H 21.500 Positioner setting: Disable Satellite scan : FAT level : 72% Quality: 0% i don't know why its not working what should i do to make it work. i have Nagravision, but when i store the key it doesnot work.. Do i have to download the niagravision2 and store the keys too? if yes then how should i download the niagravision2.. I have the bin and the 9pin cable .. so what should i do next t make it work please help me
