Thread: "Bad Signal or Scrambled Channel" |
| Posted on Monday, December 26, 2005 - 04:37 pm: |
Hi all, I have a Pansat 3500s. Been following the instructions here. Got the latest BIN file and flashed the reciever. I used Thrill's Dishnet codes, but i still get can get the reciever to unscrable the channels. I should be picking up from the ECHO sats right? My signal is ok at 90%. TIA! |
Gold Member Username: Thill1951akalk
Post Number: 1234 Registered: Oct-05
| Posted on Monday, December 26, 2005 - 07:03 pm: |
If U used the latest 3500 bin, then U don't need to install new DN keys...U just set the default keys and the autoroll will take over,if U wait and let it..as long as U have the dish aimed correctly and the remote antennae configured right..U should get 110 -119 Dishnet and 91 Bev, if U have the 3 LNB aligned .. |
| Posted on Monday, December 26, 2005 - 07:18 pm: |
Thanks Thrill, I think alignment is the problem. Is there somewhere on the net where I can find the proper alignment of all 3 LMB's. I am getting 90% signal from ECHO sats but I dont seem to be picking up the right channels. I need to verify that they are pointed in the correct direction. Thanks for your help, |
New member Username: Miss_nessa_905
Post Number: 10 Registered: Dec-05
| Posted on Monday, December 26, 2005 - 07:24 pm: |
my pansat 2300A hasnt been workin 4 a couple of days...i think da keys r wrong can someone plz help me im new @ dis...n plz help me 2 put it in plz n thxs |
| Posted on Monday, December 26, 2005 - 07:44 pm: |
I guess to re-clarify my question Thrill, which sat/direction do I need to point the single LMB dish and also for the 110/119 LMB dish. I think If i know which sat/direction I can get it from there...thanks |
Post Number: 1235 Registered: Oct-05
| Posted on Monday, December 26, 2005 - 08:20 pm: |
Aim towards Mexico...there are many satellite finder calculators software at every DSS site...U just enter your zipcode and it'll give U the direction in both azimuth and elevation where to aim the dish for each LNB.. 1 LNB = 1 satellite...110 W....dishnetwork 2 LNB = 2 satellite...119 W...dishnetwork 3 LNB = 3 satellite...91 W....Bell express Vu |
Post Number: 1237 Registered: Oct-05
| Posted on Monday, December 26, 2005 - 08:24 pm: |
These will help U aim the dish and LNB's.. Satellite Finders (Look Angle Calculators) ------------------------------------------------- http://www.arachnoid.com/satfinder (Dish 500 support) http://www.satellitenut.com/calculators/SatelliteHeading.html http://www.hollsco.com/Products/SatCalc/ http://www3.telus.net/rampage/skew.htm (Dish 500 support) http://www.remotesat.com/lookangle.htm |
| Posted on Tuesday, December 27, 2005 - 08:05 pm: |
Thanks Alot Thrill, I got my system now up and running. Great work! |
