Thread: Picture freezes |
Bronze Member Username: Eccoman
North bay,
Ontario
Post Number: 13 Registered: Jun-05
| Posted on Monday, December 26, 2005 - 08:16 am: |
I am using a Lifetime ultra and while I am watching the picture will freeze occasionally for about 1-2 secs. Does anyone know if there is a fix for this or why it does that |
New member Username: Louwho31
Post Number: 4 Registered: Nov-05
| Posted on Monday, December 26, 2005 - 10:00 am: |
I have a pansat 2700a only days old...api : 1.32c_eubx . 6 dec 2005....it freezes with a number in the display 0-9 sound sometimes keep playing...then after 2-5 seconds the box reboots...and comes back to the same show....might be the box or the new code...X-87BL_051206_132_au(N)....was freezing last night every 10 to 30 min ..been on for 1hr this morning ...no freeze...any one else hve this problem?????thanks lou as for as the fortec .. i have one of them and it froze on occation then just continued on...that could be low sig quality.. what is your sys info and bin file used ....is this fortec star ultra??? need more info ......how often does it freeze....was it raining???..... |
Gold Member Username: Thill1951akalk
Post Number: 1207 Registered: Oct-05
| Posted on Monday, December 26, 2005 - 10:08 am: |
That pansat 2700 132 bin is old and has freeze problems...update it to the 140 autoroll bin! Fortecs have very limited software,most with issues..must either update to the clone safe 282T 20 dec bin or use the older 256T Pansat clone safe bin.. |
Post Number: 5 Registered: Nov-05
| Posted on Monday, December 26, 2005 - 10:20 am: |
Thanks thill1951....im on it ....lou |
