Home > Message Board > Home Video > Satellite TV > Archive through December 23, 2005 > Satellite Scan never completes
Author Thread: Satellite Scan never completes
Username: Raj909
I have a Pansat 2700A with 1 DirectTV dish set up for 61.5 and 1 Dish500 Dual LNB dish set up for 110/119. Satellite scan completes for 61.5 but never completes for 110 & 119. Keeps looping and stuck on 12xxx and percentage complete doesn’t move. Both dishes are connected to a Coolst 4x1 switch. I have set to Factory Setting and still no luck. Thanks
Here is my setup:
61.5
echo 3/ku
LNB Local-Freq = 11250
DiseqC = 1
Level = 79
Quality = 99
110
echo 8.6/ku
DiseqC = 2
Level = 79
Quality = 99
119
echo 7/ku
DiseqC = 3
Level = 79
Quality = 99
Username: Hamtec
Post Number: 347
do not set factory settings that will not help you.... Load bin and set default keys let it auto roll and all is good!!!!!
No1b4us
Run scan on each satellite separately, then hook up switch.
This is why.
No1b4us
This is why.
No1b4us
This is why.
Username: Raj909
Thanks No1b4us, that did the trick! Much thanks.
Home > Message Board > Home Video > Satellite TV > Archive through December 23, 2005 > Satellite Scan never completes [ « Previous ] [ Next » ]
