Thread: Any one with reall keys for dish network!!(my pansat 2700a is down) |
New member Username: Harperm
Alabama,
Ms
Usa
Post Number: 4 Registered: Nov-05
| Posted on Wednesday, December 21, 2005 - 08:16 pm: |
hey i tryed the keys that are available out there,but nothing is working,i need someone with reall keys.looking for help in here! |
Letmeon Unregistered guest |
| Posted on Thursday, December 22, 2005 - 09:20 am: |
AF 0C BD 48 D8 51 6D DC FE 44 D6 0C A3 6E 59 42 (note these keys ARE FOR ALL RECEIVERS) and they work ! Make sure u enter them under N2 entry point NOT N1 point..... |
Gold Member Username: Thill1951akalk
Post Number: 1131 Registered: Oct-05
| Posted on Thursday, December 22, 2005 - 09:22 am: |
ALL the newest keys are posted in the "NEW KEYS" thread..the keys are the same for every receiver...they do not change by receiver type..they work on all Pansats, Fortecs, Co*olsat, Viewsat,Digiwave, clones etc...its even posted there how to input them...and if U were smart U would upload an autoroll bin and not need to manually input the keys! |
| Posted on Thursday, December 22, 2005 - 10:00 am: |
mine did not work until i put those keys in both n1 and n2, last ditch effort but it works. |
Mighty Thor Unregistered guest |
| Posted on Thursday, December 22, 2005 - 01:06 pm: |
Which Autoroll bin do you suggest for the Lifetime Ultra and where did you get a reliable Copy? I am very carefull about what I down load after recieving a couple of nasty bogus bin files. |
Post Number: 1147 Registered: Oct-05
| Posted on Thursday, December 22, 2005 - 01:20 pm: |
Listen up! With a Fortec Lifetime Ultra, you ONLY have two choices for bin files: 1) 282t bins (whichever key update) 2) 256t or c bins (again, whichever key updates) DO NOT TRY to use anything other than the 282 or 256 bin files. You have been warned! Pro's and Con's 282t Pros A) Colors are bright, and controls from remote seem normal B) Safe to use with all versions of Lifetime Ultra 282t Cons A) When installing new bin file (when keys change), you need to do a complete re-set of the satellites, channels, etc. B) No manual key change is possible with this bin file series. 256t or 256c Pros A) Manual key change is possible. Method is well documented. B) If you rename satellites correctly, you can get Dishnetwork channel listings to show correctly. 256t or 256c Cons A) Colors on TV are too dark. Not as bright a picture for some reason. Very annoying! B) Remote menus not as straightforward as for the 282 version. Also, so far I have NOT seen any evidence that either of these two bin series have "autoroll" feature. That is, the ability to automatically detect and change the new Nag2 keys when they come around. Just not available with the Fortec Lifetime Ultra.
| Posted on Thursday, December 22, 2005 - 01:32 pm: |
Gracias, I have the current bin file running and working, did not know that the #s could not be entered manual. Good to know. Much appriciated. Keep hearing about an auto roll bin but as you implied, rumors are plenty facts are few. |
New member Username: Bugster999
Katy,
Tx
Post Number: 1 Registered: Dec-05
| Posted on Thursday, December 22, 2005 - 01:55 pm: |
How do I put these keys into my receiver? Or where I can find the current bin file went to future but it looks like it is down. |
Bronze Member Username: Trucker
Post Number: 14 Registered: Oct-05
| Posted on Thursday, December 22, 2005 - 11:15 pm: |
there is a moded pansat bin 267t out there that supose to autoroll, and will work on fortec ultra with a good chip set. |
| Posted on Friday, December 23, 2005 - 09:29 am: |
Hey Thill, can you suggest the same for pansat 2700a receiver. I want to know which is the best bin. thanks, |
header108 Unregistered guest |
| Posted on Friday, December 23, 2005 - 05:14 pm: |
I just received a new Pansat 2700A and put the new 140 bin on it right out of the box with no problems. Keys rolled and EPG works great after you setup time and date. Nice Bin!!!!! |
New member Username: Kodeedotcom
Post Number: 3 Registered: Aug-05
| Posted on Friday, December 23, 2005 - 05:29 pm: |
I have a Pansat 2500a and did a Sat scan. I do not have as many PPV channels. Can any tell me why or am I doing something wrong? |
New member Username: Loveboy
Inkster,
Mi
Usa
| Posted on Saturday, December 24, 2005 - 02:15 pm: |
i have 2700A n i dont no how to setup n how downlond the binfile
| Posted on Saturday, December 24, 2005 - 02:22 pm: |
Do you have a switch in the line to lnb's? Take it out and scan 1 at a time the reinstall it. |
New member Username: Miss_nessa_905
Post Number: 3 Registered: Dec-05
| Posted on Saturday, December 24, 2005 - 07:14 pm: |
my pansat 2300a doesnt work can somebody help me plzzzz |
New member Username: Capljinac
Post Number: 2 Registered: Dec-05
| Posted on Saturday, December 24, 2005 - 08:10 pm: |
Need Help! My Fortec Ultra is Down,wrong bin 284, my mistake did not double check. I just purchased Pansat 2700a and need 140 bin with auto roll. Please if somebody could help me and send on my PM the 140 bin. Thanks capljinac@yahoo.com |
