Home > Message Board > Home Video > Satellite TV > Archive through December 23, 2005 > Dec.20 Fix for Fortec ulta
Author Thread: Dec.20 Fix for Fortec ulta
biverland
The fix is on : dss.tester.com
you have to registes to get....its free ...
Iqbhu
umm yah, but CNN channel doesnt work? any solutions??
Iqbhu
Username: Ashkit
I have a X-05BL_051213_136eubx_au_api.bin file for autoroll in fortec lifetime ultra. Will this file work for autoroll. Also does any body know what file I need for BEV. Any help is highly appreciated. Thanks
Good Info
Yes. Fox News!!
Username: Tomuch4you
New york
Usa
Post Number: 51
I just put the new pin file in my lifetime ultra
and I go CNN channel back and a few HBO channels
also. I used the FTA ultra 282-t2-12 h-clock.api
everything is working fine. I want to thank you
all that are help to get free tv working. Bye
Username: Wassupmane
what is the code you put in the code box when trying to put in keys. Please help me with this!
New york
Usa
Post Number: 52
My friend if you have the lifetime ultra the keys
are in the pin file. Just read my post and put
the file in your receiver. You should be watching
tv in a very short time.
code for key box...1010 or 1668 this won't help
you if you got my box!
Username: Kingeverton
Kingston jamaica
what must i do to get HBO NBA SHOWTIME pleASE CAN SOMEONE HELP ME, IHAVE A PANSAT 2500A THANKS IN ADVANCE GUYS
Username: Cdog
how do i get to the keys so i can change them in a cooltec
Username: Jasonswife19
Can't get access to that site. Comes up page not found.
biverland
... olso you can get this file.. at http://www.fsfta.com/
biverland
http://www.dss-newbies.net/
http://www.kf2a.com/
olso on this ....its free ..but you have to register ...its simple ok ...have a nice day..
for the good of FTA
Any Mouse
@ Lisa
loose the dot between dss and tester ie. dsstester
biverland
http://www.Al7bar.com/
http://www.hashhucom/
biverland
are evrybady up ... ???
Are the fix fom 20dec ... 100% ok for evrybady .. Fortec Life Ultra....
mtl
Hi biverland,
does not work for me. I lost Tv a few days ago no coding seems to work.
What i can do, where to find the code to enter and get my tv back.
feel free to email me at vicwin_2@hotmail.com
Username: Highlyaccurate
Hello Guys
Any body can help me, for new keys about fortec ultra
George438
Biverland,
Here, the fix from 20 dec for Fortec is working... except tp2 on 119 (no signal quality at all). Everything else seems ok. I wonder why that tp is out... Or does DN moved everything that was on that tp? Mmm... A powerscan gave nothing...
Home > Message Board > Home Video > Satellite TV > Archive through December 23, 2005 > Dec.20 Fix for Fortec ulta [ « Previous ] [ Next » ]
