Thread: Cant get any signal!!! |
New member Username: Noic
Post Number: 1 Registered: Dec-05
| Posted on Thursday, December 15, 2005 - 02:31 pm: |
hi, I have 2 fortecstar ultra, with the same bin file, the "282t dec-01-2005". the satellite settings for echo 7,6,8 are the same in the 2 box. in one box a get the satellite signal very strong 90% "red and green line". but in the other one I dont get anything, just 30% of the red line, but not the green one. I'm new with the free air box. what can i do to get signal in the box. thanks |
switch settings Unregistered guest |
| Posted on Thursday, December 15, 2005 - 02:39 pm: |
under antenna setup make sure you have the same set up as the one that is working. Your switch settings maybe off. |
Post Number: 2 Registered: Dec-05
| Posted on Thursday, December 15, 2005 - 03:08 pm: |
the 2 box have the same settings for the antenna. the diseqc are #1 and #2. they have the same settings. i dont know what you mean by switch settings are off..
Beat_This Unregistered guest |
| Posted on Thursday, December 15, 2005 - 03:42 pm: |
Your frequency is wrong that's why it is showing red, change your frequency in the settings to 11250 and you are good to go. |
Post Number: 3 Registered: Dec-05
| Posted on Thursday, December 15, 2005 - 04:26 pm: |
hi beat_this I put the frequency to 11250, and still the same. its blue, in the 2 box. one get the blue and green and works great. but the other one just 30% of blue, but nothing in the other line. is very strange!!! because they have the same settings.
hotpussy Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 08:13 pm: |
www.GAT-s.biz Plentyoffish.com Free Online Dating Service & Dating Site
Grimreeper Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 09:03 pm: |
switch the boxes around hook working were non workin one is if it then doesnt work you have a lnb or cable prob |
