Home > Message Board > Home Video > DVD Players > Archive through December 25, 2005 > Why would a multi-region DVD play reg...
Author Thread: Why would a multi-region DVD play region 1 disks in B&W?
Username: Fellaw4
London
UK
Post Number: 7
Hi
I have recently been given a Sony DVP-F21 dvd - I think it is a couple of years old.
Although it is meant to be multi-region, all my Region 1 disks will only play in black and white for some reason.
Does anyone know why this might be, and is there any easy way around this?
I hope someone might have some suggestions!
Thanks
Deano PJ
Try plugging it into the AV1 socket on the TV or the AV socket marked up as RGB if not AV1. worked for me.
Username: Samijubal
Post Number: 1986
Is it a PAL player and an NTSC disc, or vice versa? If so, that's the problem.
Home > Message Board > Home Video > DVD Players > Archive through December 25, 2005 > Why would a multi-region DVD play reg... [ « Previous ] [ Next » ]
